It's built into the tyre.
You need a tyre with a "Z" speed rating. eg 235/45ZR-17
why does he need a Z rating? not doubting you, just curious as an R32 GTR is factory limited to 180kmh.
here are the speed ratings: http://www.tyresave.co.uk/tyrspeed.html
Krzysiu, I doubt you have 'R' speed rated tyres. Looks you got 18" wheels?
You probably saw something like 235/40/R18. In this case the R stands for Radial, the tyre's internal construction.
These days the speed rating is shown after this, along with the load rating.
For example 235/40R18 93W. Where the 93 is the load rating, W is the speed rating.
In the past the speed rating was shown within the tyre size. eg 235/45ZR17, like blind_elk said. Maybe some tyre manufacturers still do it this way.
http://www.tirerack.com/tires/tiretech/gen...neral/speed.jsp
Z - Rated = As fast as your car ca push em (technically suggests 240km/h+)
Y - Rated = Up to 300km/h
W - Rated = Up to 270km/h
V - Rated = Up to 240km/h
H - Rated = Up to 210km/h
U - Rated = Up to 200km/h
T - Rated = Up to 190km/h
S - Rated = Up to 180 km/h
R - Rated = Up to 170km/h
should have a letter on the tyre somewhere after the size...eg 235/45/R17 Y
or 235/45/ZR17 in Z rated case
Trust a Y speed rating over a Z
Y have been tested up to 300km/h and can travel at those speeds.
Z have only been tested to 240km/h, but are believed to travel over that speed (although they have NOT been tested over 240km/h)
Here is some info I got from a website a while ago...
Here is the rating information for speed:
M 81 mph 130 km/h
N 87 mph 140 km/h Temporary Spare Tires
P 93 mph 150 km/h
Q 99 mph 160 km/h Studless & Studdable Winter Tires
R 106 mph 170 km/h H.D. Light Truck Tires
S 112 mph 180 km/h Family Sedans & Vans
T 118 mph 190 km/h Family Sedans & Vans
U 124 mph 200 km/h
H 130 mph 210 km/h Sport Sedans & Coupes
V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars
When Z-speed rated tires were first introduced, they were thought to
reflect the highest tire speed rating that would ever be required, in
excess of 240 km/h or 149 mph. While Z-speed rated tires are capable
of speeds in excess of 149 mph, how far above 149 mph was not
identified. That ultimately caused the automotive industry to add W-
and Y-speed ratings to identify the tires that meet the needs of new
vehicles that have extremely high top-speed capabilities.
W 168 mph 270 km/h Exotic Sports Cars
Y 186 mph 300 km/h Exotic Sports Cars
While a Z-speed rating still often appears in the tire size
designation of these tires, such as 225/50ZR16 91W, the Z in the size
signifies a maximum speed capability in excess of 149 mph, 240 km/h;
the W in the service description indicates the tire's 168 mph, 270
km/h maximum speed.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
