Day Cruise
R33S2
 Share
the meeting place is going to be the parkin spot next to cannon hill maccas ill be taking pics and stuff can play match and find if they cant find it
There is NO car parking spot NEXT to cannon hill macca's
do you mean the Cannon Hill Macca's Car Park?
Just Letting Everyone Know That The 25th Is The Public Holiday Not The 18th. You Might Want To Double Check Your Dates.
Cheers
well that makes the 18th out for me (ponders seriously) shoulda checked dates thought you did well you were wrong.
well i failed once again to upload maps, is this a sign should i give up still cant access Qld forum, I will be there at 1 pm till 4pm sat 16th if you wanna show up come along ill endevour to get pics of each car and post after.
Terry I have NFI what you mean by this... You are in the QLD forum posting?? How do you mean you can't access it...
:confused:
I see you have created a thread in the Feedback section asking for help on this too... This is probably for the best since if there IS a problem, it will have to be fixed by the admins, not the mods...
Totally related topic...get over it.
How about you pull your head in Andrew. Sarcasm is the lowest form of wit and you are showing at least half of it.
As for organising. I have seen many other threads of the same nature which take shape over many days or even weeks in some cases. As long as people keep checking the thread up until the day, there shouldn't be any problems.
Terry should post a final message with a unanimous meet point and date/time when everyone confirms their attendance.
No need for maps I would have thought. Maccas is pretty easy to find. It's on Wynnum Road isn't it. If you are coming up the Gateway (inbound) take Wynnum exit and turn left onto Wynnum road follow it through three sets of lights and it's 100m on your right.
If you come down Creek road from Carindale, just turn left onto Wynnum road and it's 100m on your right.
If you are coming from the City. Go via the story bridge, past the shafston hotel and follow it continuously until you see it on your left hand side...(there are no other maccas on the way after shafston hotel so as soon as you see one on your left...that's it)
Oh yeah...if you can't find it...you're an idiot.
your organisational skills are right up there with your IT skills :P
Opions like this waste space on this thread if you must air your considerable knowledge take it to whoretown or pm me direct
Ok, this is just stupid.
Terry, organise a spot, a time, a date and make sure where ever you organise it, it's easy to get in and out of without too many traffic lights so people get caught and dont catch up.
We all have to start somewhere people, give him a break. He's trying to organise a cruise for people who have expressed interest. That's all they have done and sat back and waited for someone to take the lead, Terry has done this, give him a go eh?
I'll close this thread and when you've made a decision on a date, place, and time, repost it.
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
