Just got mine dyno'd on the weekend. Only put out 95kw atw due to the fuel pump being stuffed. Was leaning out to 15:1. Should be putting a new pump in on the weekend so i'll update the figure when it gets on the dyno again. Mods are 3" dump and front pipe, 2.5" cat back. Everything else stock as. RB25 turbo and EBC to be installed very soon.
