HKS GT2510 - 300 PS Output
COMPRESSOR:
-Wheel- 63 Trim - 47.7 Inducer / 60.1 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE: -Wheel- 62 Trim - 53.0 Major / 41.7 Exducer
-Housing- GT25 inlet / Internal GT25 oulet - 0.64 A/R
Its a hell of alot bigger than a standard RB20 turbo though, do you think it would produce 300hp? with mods such as stainless manifold, stainless dump, 3" zorst front mount bigger injectors, fuel reg, bigger fuel pump running more boost?
Seems like that is what mine is, as it doesn't matter how much boost you wind up, it seems to run out of puff at around 200rwkw. The response if awesome though, very little lag
Mine made 200rwkw at 1.0bar, and has made 205rwkw at 1.3 bar - but at 1.3bar there is a extra 40rwkw at 100kph, so it gives it a big mid-range hit of power
Trying to work out if anything poses a restriction on my car at the moment, 210rwkw would be nice, even 220. Maybe with cams and cam gears it may get there
HKS seem to rate their tubos about 10% conservative.
So 330 PS = 245 kw - 50 kw for transmission losses = 195 rwkw.
Looks like HKS and I agree.
Pretty irrelevant in this instance, a it simply runs out of airflow. So no matter how much you improve the efficiency, it has no more flow to give. Reducing the restrictions would (as always) result in lower boost levels, but they have no effect on the maximium airflow.
:P
Do you have a dyno-graph? I was looking at a 2530 eventually but i think i'd be happy with those numbers if a gain in response was there with a 2510.
yeah sure
this is before and after - before was stock injectors/chip
after PFC and injectors
I want to try some cam gears next to try and get more top end - at the moment its pointless revving it over 6500. I want to move the power up in the rev range
It would make a awesome drift turbo, lots of torque midrange
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
