hi guys and girls,
i've been wanting to do some research on R33 front conversion to R34. at the moment, i haven't been very successful. do you guys know much about the conversion? for example: the price range, the workshops, any links?, etc...
what procedure must be taken for this front to be implemented?
any advice or help would be appreciated, thanks! :headspin:
like this one:
https://www.sau.com.au/forums/topic/69289-r33-front-r34-conversion/
I know the company that does them in Japan are called Bee R
Theres an article on one of their 32with 34front's in latest Autosalon Mag, I dont believe theres any here in Aust, so it would be a custom effort from a place that is willing to try.....and i'm guessing....BIG dollars... i'd guess 10-15k???
theres a photo/thread somewhere on the forum, do a search. Pictures of a black 33/34 on there, looks better finished. Looks SWEET!!, if only i could afford the conversion, i'd have it done too
hey theres a biz called driftline racing in cambellfeild who is thinking of doin these kits for 32/33 to 34 and if roshan gets enough interest hell oorder the br kit in and start doing them as he all ready does the strawberry face conversions that g-13 started and never got any were to finishing that 10,000 doller sum is for drive in drive out with whole kit and new paint job so will be about 3500 to 4 grand for the whole kit fitted
the above picture is uras' car. U can buy the fenders from yahoo auctions. but that uses a genuine r34 gtr front bar and headlights. u will need a new radiator support bar and reinforcement. IT uses a genuine r34 gtr bonnet as well. don't quote me on all of this but all in all it will b expensive.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
