Hi,
I have an RB20DET tuned chip for sale for $50. This chip has had the speed (means you can now go over 180 kph) , fuel and boost (mass air flow) cut removed. The ignition and fuel maps optimised to help boost come on slightly and help reach max power.
To install the chip you will need to
- remove ECU from car.
- take the ECU to someone (electronics place) who will de-solder the stock chip
- once the stock chip is removed they will install a cradle.
- once the cradle is in you simply need to slot the new chip into the cradle
- then re-install the ECU.
If you are looking at purchasing a tuned chip or aftermarket ECU etc. you will notice that this price is very cheap. It is not too good to be true, I'm simply not interested in mucking around and would like to get it out there.
The chip will provide you with a top end improvement - it will feel as if the car breathes abit better. Unigroup commented at a SAU dyno day a while back that it was a good power tune. I wish that I had a dyno chart from the day with the A/F line on it - but I don't.
The chip was tuned for a car with FMIC, 1.2 bar boost, pod, exhaust - the usual stuff.
Below is some food for thought for RB20 tuners.
https://www.sau.com.au/forums/topic/69291-rb20det-tuned-chip-50/
Hi Ed,
It will run just fine at 13 psi (I run only 14 psi). I don't know how much of a difference you will notice on a reasonably stock engine - I recognise the most difference when boost gets up above 12 psi due to the removal of the mass air flow cut. I imagine that any auto electrician can do the work - really anyone with a solder sucker can do it.
Thanks, Ben.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
