We are able to get hold of locally made Attessa controllers which work with R32, 33 and 34 GTRs and GTS4s.
These controllers allow you to choose from 10 settings from 100% rear drive to max available front torque.
$350, +$50 installation if you want us to do it for you...it is very simple though, 5 joins.
The kit uses the standard FM radio controls on the dash on the R32, or a switch on all other cars. An LED displays which setting you are at 1-10.
Pics will be posted in the next few days, as they are made to order you will need about 1 week's lead time.
https://www.sau.com.au/forums/topic/69301-fs-attessa-controllers-350/
  • Replies 317
Posted Images
Guest two.06l
We are able to get hold of locally made Atessa controllers which work with R32, 33 and 34 GTRs and GTS4s.
sounds good Dunks,put us down for 1 unit
Damn it, just bought an M's ETS last week... Still interested to see some pics and info on this thing...
Does it wokr by constantly applying drive, or does it modify the amount of drive given by ATTESSA like the AutoSpeed example? Does it interface to the Front Torque guage too??
Hi all, pms all replied to, and a couple have been sold and we are making them up.
re Pics, I am still sourcing them, but there is really nothing to see....little black box with the brains, and LED and a switch to adjust up and down. Box lives in the console next the the g sensors, LED on the dash where the driver can see it and switch wherever suits :rofl:
re operation....basically this works along the lines of the Autospeed one, it intercepts and modifies the output of the g sensors to get the required front torque.
Simple, which is why we can get them at a good price :D
Hi Duncan,
In regards to the standard radio operating the unit.. is that the toggle switches on the left of the drivers gauge consol as opposed to the centre consol (32)? My car came with an aftermarket stereo so not sure if the stanndard radio was mounted in the centre consol and like some modern cars there was also control switches nearer the driver. Cheers
Oooh oooh , Duncan.
Put me down for one as my GTR will hopefully be here in about a month.
For those who haven't driven with a torque split controller in the wet, they are brilliant. Had a HKS one in my Targa GTR and it makes a big difference to the balance and control on unknown wet, slippery. scary roads...
I believe you can't get the HKS ones for R32's anymore but that is no excuse to raise the price :D
Cheers
Ken
Sorry, is this TSC excatly the same as the one by 'R32 combat' in WWW.GTR.CO.UK?
If so, I'm interested, but would like to at least see a picture of the gadget first.
Hi Ken, Correct me if I am wrong, but the HKS ETC units gave constant drive, like you dial in 35, they give 35 constantly, these units modify the way in which ATTESSA control is delivered, like the ones shown in AutoSpeed. This will give you no drive when you don't need it, but a different drive to the stock ATTESSA controller when it is needed dependant on the level selected by the driver..
I just recently purchased a Second hand M's ETS for $375, which I think works in the same manner as the HKS ETC units.. The HKS ETC is no longer available, the only ETC available anywhere seems to be the GRID units.
Sorry to hijack thread, just thought it would be good for people to repsond and to clear up any confusion.
Once again, Damn! This is about a week too late.. Otherwise I would probably get one of these, I am considering making my own one form the Autospeed articel anyway..
Hi Duncan,
Hey Conrad, yes that's the radio controls I mean, the one on the dash not on the head unit. But don't worry too much about that, we can provide a seperate switch if you need, its just not as much of a stealth install then :D
yaf28f, it may well be similar, I don't know anything about the GTROC units. These were designed and are being built by a supplier in Sydney.
Yeah Yorik, that's right, the HKS units can provide a constant torque split, this does not. It basically increases the sensitivity of the sensor depending on the setting you choose, the effect is _more_ fwd when you need it.
And it is very effective....we generally run it on setting 3-4 on a dry track and 6-7 on a wet track, it provides plenty of FWD when you need it :P
pms sent to other purchasers
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
