  • Replies 317
Posted Images
Hi, I am still interested in a TSC, but with an analog Dial. Don't want another flashing LED near the Dash, I wouldn't plan to adjust it very often. and it would be easier to swap it to another car or sell later on.
Will it take long to make one up with a dial? thanks for the pictures, they look much smaller than the ones they were selling in the GTR.CO.UK ones.
Are these g-grid???
Hi mate, no these are not g-grid controllers, they are made locally, and are very effective :D
Thanks Yorik, got your order, we will organise it next week on our return from Targa
hey do u have any pics yet??
i will b interested when my GTR arrives later this month
Hi l005e, please see my earlier post (#39). There are no visible parts to the controllers except a switch to adjust more or less torque, and an LED to indicate the level. The box hidden under the console - Mark posted a pic of the internals in post #34.
:rofl:
there are still units available for those who are interested :)
OK here is the long awaited external pic. The black box goes all the work and lives under your console.
The red, black, blue and green wires are connected to your g sensor, the led is mounted in the dash where you can see it, and the yellow, pink and blue wires in the black cover go to the switch (whether radio controls or regular switch).
The kit comes with full installation instructions including pics.
Hi Tony....nope we can't get 100% front torque.
What we can and do get is "maximum" front torque as shown on the torque split guage when used with a healthy transfer case. I don't know how much that is exactly but the 32 GTR system cannot provide 100% front torque (ie all FWD no RWD).
Hi,
So basically, i would want this controller if i wanted to be able to switch from Full RWD to normal type attessa mode at an instant?
as you say 100% available front tourqe, so its not switching in a permanent 40-60 split or anything, its just letting atesssa do its job?
am i understanding correctly?
thanks v much.
love the stealth install with teh am/fm radio buttons.
michael
Guest mark32
Basically the way the gtr splits its front wheel torque is the sharper the corner it goes around the less drive goes to the front wheels this is to make it fell like a rear wheel drive car around corners (so as to make it an oversteerer on powering out as opposed to a constant four wheel drive car which understeers on power out) The car knows how sharp a corner it is going around by feedback from the lateral g sensor (located under the console) if you degrade the signal coming out of the g sensor it will transfer more torque to the front wheels on corners and this is adjustable in 10 steps, but it wont give you a constant 50/50 split or any other degree of constant split, but it will give you a way of adjusting how much front split you have on corners which is where most people want it. So as to balance the car better on the exit of corners to suit your driving style or road conditions (wet/slippery). As Duncan has already said they are a very effective device
Guest mark32
Also this device will switch the car into 2 wheel drive mode on r32 gtrs same as pulling the fuse on the attessa computer or there is another mode which allows the front split to come on very moderately which is good if you want the car to be taily like for drifting
I can vouch for these units - have had one installed in my R33 for about 6 months now, and it has been one of the best things I have done to the car. Left on "1" the car drives totally normally, with progressively more cornering grip until about "5" or "6" in the dry. In the wet, on "10" when the light is permanently green, I could not get the car to oversteer at all when I tramped it around a roundabout on hotmix asphalt in pouring rain, although my car is pretty mild (only 240awkw). As has been previously mentioned, it does not help with launching in a straight line, is only for those who want more grip around corners. You do get a bit more understeer in the higher modes in the dry, but easily dialed out with suspension adjustments/swaybars etc. Installation took 30mins, and is very unobtrusive - on my 33, I just have a switch mounted behind the gearleaver to change modes.
Definitely a quality gizmo.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
