  • Replies 317
Posted Images
The radio itself still works fine....what we do is use the switches on the dash near the steering wheel for the controller instead, so they no longer control the radio.
But you always have the option of a seperate switch and keeping the dash radio controls for the radio....if you ever use them :)
Just wanted to say thanks Duncan with the install and Mark for making the unit.
Finally had a chance to play with it and definately makes a difference and just have to work out the setting best suited for me. Good work guys.
Hi Andrew, I've just emailed the details across to you :)
For everyone else interested, there are currently 3 available so we can get them sent out pretty much straight away D:
Hi, I'm interested. I would like to fit one to a R32 gtr. Please contact me
Thanks
I saw what the extra plates in the centre do on Snowies car, and while good for track, not good for tight stuff so this is a better solution for all 'round. I'll grab one after I recover from surgery in a month or so. No sense depriving the needy when I can barely drive :)
Actually I'm pretty sure that R32GTS4 is the first to try one on a gts4, but I am 99.9999% sure it will be fine as it uses the same system.
There is 1 available from the current batch or you can see how he goes and grab one later :cheers: You will love it :)
Just a quick update to the manual for everyone that has bought one of these.
There are actually 2 RWD modes on the controller, not one as the manual states.
1) Hold the down button down for 5 sec and it goes into "almost-rwd". There will be basically no front torque except under extreme conditions, but your ABS will still work and there will be no ATESSA warning light
2) Hold the up button for 5 sec to put the car in full RWD mode, this will also stop ABS working and the ATESSA light comes on, but there will be no front torque at all. This mode is the same as pulling the 4wd fuse.
Hey Geoff yes all the RWD only mode will work on all ATESSA systems....but it doesn't change how the 33 and 34 systems work and so you might damage them using the RWD only mode. So my recommendation is only use the RWD mode in a 32....unless someone wants to test it out for me lol
It could be ok given the clutch pack nature of the transmission system. My take is the 33/34s have more preload initially but don't know if that is electronically controlled or a physical relationship. Certainly some of the Jap controllers allow for full RWD on these models unless I've crossed some lines somewhere.
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
