Yeah, for motokhana applications the ability to have a quick stab of zero (or absolute minimum) front torque to bring the back around is a tops idea.
If you look at the Evos when they turn around cones, they almost pivot. I know that some of them have the Motec centre diff controller and they can do similar things.
You would want two buttons. On for Maximum and one for minimum front torque.
oh, and if you need a car to try it one, we have a couple!
BASS OUT
  • 4 weeks later...
  • Replies 317
Posted Images
sorry Bass these 3 are spoken for, I can put you in first for the next batch if you want...but at this stage the next batch won't have the mods for min and max torque, the guy that makes them is tight for time atm...so let me know if you would rather wait for the updated version
I need a t/s contoller and have been toying around with the same idea of running a more rwd at first at motohkanas to stop the car bogging down and also to reduce the understeer. Will save slipping the clutch to get going. A bad habit that comes from the 2stroke motorbike days. It would take a little to get used to as you have to correct the wheel to oversteer really quickly when this happens in gtr's.
If you were smart enough it could be plumbed into the steering sensor so when the wheels where close to where the car understeers it would reduce the torque split?
  • 4 weeks later...
Hi Duncan, put me on the list for one od these once they are available again.
Cheers
Yup, same goes for me too please Duncan.
Got any ETA's at this point?
Matt.
"If you were smart enough it could be plumbed into the steering sensor so when the wheels where close to where the car understeers it would reduce the torque split?"
The attesa does that for you, the g sensors going foward and back are more sensitive, the more g force the higher the wattage signal goes to the computer resulting in more fwd. However the g sensors going from left to right reduce the wattage going to the computer as the g reading goes up, ie it becomes less sensitive the harder you corner so the gtr doesn't have the same 4wd characteristics as an evo or wrx/understeer.
This unit doesn't take "control" of the ets as such like the other units available. Its more of an electrical current amplifier? (spelling) to increase the sensitivity and performance of the existing unit, not to outright manipulate it, the higher the setting, the higher the electrical signal making the 4wd more reactive, correct?
Its an amazing idea as the system thats in place is perfect for the car, but not as reactive as I would have hoped for so this mod would be great for fixing the standard system.
With that said, put me down for one. Please pm me with more details if there are any.
Cheers, Nick.
Waiting list:
Bass Junky
R32GTR
R32 TT
ShadowGTR
Anyone else interested please post up I will allocate them in this order....will contact you for payment details when they are ready.
Yes that is the basic principle, but the output of the controller is not linear like simpler ones, this is controlled/programmed by a chip onboard instead
BTW Mark I have the controller back from Nathan, will drop it by next time I'm in the area
Bass Junky
R32GTR
R32 TT
ShadowGTR
IanB
Im in. Contact me for payment details ASAP please.
I was so disappointed in the GTR AWD system when I took it for a hard run over the mountains, not enough FWD at all.
From what I understand, this system doesnt lock it into say a 70/30 split or a 5050 split, it meerly makes the stock system work better, eg, when you corner, it puts more power to the front wheels, what you control is how much more, correct?
Edited by IanB
Hi All, the current list is:
Bass Junky
R32GTR
R32 TT
ShadowGTR
IanB
Gun32GTR
Which leaves only one from the current batch being made......if you want it get on this list quick!
I'll send everyone details once they are ready to go :(
Duncan
I may have to pull out of this :D
After speaking to paul, I have found he makes a unit which is more suited for my needs. More expensive too, but much more customizeable.
Sorry to stuff you around! Im not sure if paul has any in stock, I believe he said he had a couple left, if he does ill grab his, but if not, I will go with this one still.
That being said, if anyone wants to take my place, they can.
Guest
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
