The nissan ATTESA computer lets you get a 32 into 2wd by:
Turning off the motor temporarily while the car is moving
Pulling the ATTESA fuse
Adding a 2wd switch (same as pulling the fuse just mroe convenient)
Using this or similar controllers.
But in all cases you have to bring the car to a full halt, return it to 4wd mode (ie replace the fuse, turn off the swtich or adjust the controller).
The only controller that would allow you to go back to 4wd mode would be a full replacement like the HKS fixed split drag controller....which is of course no good for track work, the standard variable controller is much better.
  • Replies 317
Posted Images
Will be interested in one of these soon, as it seems like a better idea than fitting Front and Back sets of different size rolling diametre tyres to set a constant percentage of AWD if on the circuit track or drag strip.
Has anyone else thought of this method and have any facts on actual rolling dia differences and the fixed torque split it gives?
Will PM when ready :laugh:
umm... with 1 space saver on the back (slightly smaller rolling diameter), zero throttle means 10 kg plate pressure, touching the throttle at all means 50 kg plate pressure.
I presume that any wheelspin under throttle puts full torque to the front (I think a few dirt roads have helped me come to this conclusion).
Since it was absolutley pouring, I was having immense fun.
But think about what an unequal tyre radius is doing once you are moving... the smaller tyres will be applying a braking force through the transmission, or the larger ones will be spinning. Or your clutch packs will be slipping, which is a little worse than tyre wear on a track day.
On a side note, how many mA do the G-sensors output? ...wanna try my own resistor based mod first...
Guest mark32
I cant recall how much current they output in operation but whatever you make up it is always good practice to design something that will pull as least amount of current as possible as too much will either damage or cause the G sensor to give a false reading. The PIC chip in this device draws <2mA, the ATESSA computer only looks at the voltage of the G sensors to work out what it should output. The workable voltage swing of the G sensor is between 1-4 volts
Installation easy, and didn't take long. I suggest putting the LED thought the dash lights. Got my LED going though the ABS warning light and no one would know it's there and warning light is still working, just took a little trim off the light plug. Be carful not to squash the wires if doing this way.
Taken it for a little test but can't say much because clutch is gone/going. Could hardly get it up the rams yesterday ready to drop the gearbox. :)
Good trick :P I'm glad install went smoothly....but soudns like you aren't going to enjoy it properly until you can put some power down without the clutch slipping :D
OK, I know it is fine to run an R32 GTR in RWD but is it definitely safe to run an R32 GTS4 in RWD mode too???
  • 5 weeks later...
reading through this thread
i have a few questions
would i be able to use this model.....on my r33 gts4 for warming up the rear tyres (burnouts)???
would this damage anything in my 4wd system running it on rwd for burnouts only???
and when switching back to 4wd will it be back to normal???
thanks
Hi mate, all 33 and later cars have at least some fwd at all times due to differences in the ATESSA pump. As a result you will have increased wear on the transfer case clutch packs.
Can you do a burnout or 3? probably.....but I wouldn't do it to my transfer case.....
BTW this is an issue for all controllers and 2wd modes that use the standard ATTESA system. There may be some like the HKS drag adapter that replace the standard computer that do work OK for rwd only in 33 and later. THere is no problem with running 32s in RWD mode with the controller.
This is primarily for improving handling on a street/circuit, it is of limited use for drags.
hey thanks for that, much appreciated.......i will look into the hks system
BTW do u kno what it is called by any chance?
Edited by Cro_boy_Mario
Sorry everyone I can't get hold of these at the moment, post up here if you are interested I'll put together a list when more are available.
  • 4 weeks later...
I have a question.
R34 GTR N1
What I want to be able to do it press a little button when I want to induce oversteer, ie minimum front torque.
So, coming up to a witches hat, grab handbrake, press little button, minimum front torque until finger comes off button. This allows the back end to come around a little bit more and reduces the understeer that sometimes effects the GTR on slippery surfaces on cars with big power.
That function would be excellent.
Maybe even and full torque, mininum torque buttons. Motorkhana specials!
BASS OUT
Hey pete....interesting idea, I'll pass it on to the guy who makes them. I think the lack of stock atm is due to no chips being available so it might be a good opportunity :O
3 expressions of interest received at the moment.
Guest
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
