I need to keep the standard R32 GTR airbox in my car, has anyone played around with these to improve the air flow?
The dyno killed 11kWs straight up with between running just the AFMs (unfiltered) and running the airbox.
https://www.sau.com.au/forums/topic/69312-can-r32-gtr-airbox-be-improved/
Drive it around, get it all hot, stop-start traffic, etc, etc. And i think you'll find the air box will win out.
You can try and set up some CAI ducting to supply more air to the box's inlet to get some gains, plenty of threads on that around.
There is a big ass resonator that hangs behind the front bar. Mine was filled with water.
The resonator inlet to the bottom of the airbox is a circular cut out of around 5cms diameter.
If you want to you can enlarge this hole to say 8cms and duct from your front bar vent to the side of the FMIC directly up into the airbox
I have removed the resonator but have fitted an oil cooler there
:P
On mine I removed the resonator but kept the pipe that joins it to the snout under the headlight.
By reversing it you can face it towards the bumper getting a ram air effect.Ideally you would use a bigger pipe as it does make a difference.
As for the opening in the airbox its about the same size as a 4inch pipe but a triangular shape.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
