What's the difference between a single and dual solonoid and also spec R and S on a electronic boost controller???
I am currently looking at a few on the nengun site, and the options are the GReedy or the Blitz. There are 2 options in the Blitz (single or dual solonoid) with about $100 price difference. I would have posted pics but unable to access the site this morning. They are all in the $300 - $400 range.
I am sick and tired of the fluctuating boost/ boost creep so i think the EBC is my only answer.
Can anyone recommend a good value for money EBC for a R33 GTS-t? I would like to keep the cost low as possible.
Attached picture is of the Greddy Profec B Spec II Electronic Boost Controller my friend is using on his 200sx. Is this any good? As it is one of the cheaper options on nengun's.
https://www.sau.com.au/forums/topic/69333-whats-the-difference/
