Anyone running with one of these (this is not the AVC-R is it ?)
P/N 415-A001
I have an R32 GTR and I'm just about to install PCF + CAMS + 550cc injectors
Is this a good boost control solution (match for the PCF ?)
They work very well, we have 2 on GTR's and 1 on a GTST. But there is no bling appeal, no blue screen, you just have the Commander.:P
Hi Boost
I have looked at these also, but they seem to be way over the top for what they are. MOst prices seem to be around $600 and as has been said, it is really only a solenoid valve, and sensor, no fancy screen or controller.
Ned
I also havent found any 2nd hand
Yer but it wasn’t the right bloody one was it!!!! For an R34 when you need one for a S13 !!!
i ordered one for the s13 dickhead.. you were there that afternoon it arrived i rang him told him it was the wrong one.. and he said no no its right one blah blah blah.. so meh.. doesnt help when the ****ing manual is in japanese but meh.. need injectors to see if it is working properly now anyway :D thanks to someone else...
