Does ne1 know of a way to may the lights on my R33 clear again it looks filthy when you turn them on!!!
The plastic has faded and is starting to crack =(
I have heard of plastic polish does ne1 know if this works?
Does ne1 know where i can get a replacement set for a decent price as i have been quoted $1000 for a new set!!! =(
https://www.sau.com.au/forums/topic/69345-fixing-cracked-and-faded-lights/
I use Meguiars ScratchX and it does the job nicely. It's a little bit pricey (about $20 a tube), but bonus is that you can use it on the rest of the car as well to get rid of light scratches, whereas you cannot with other things like plastic polish, toothpaste, Gumption etc.
  • 6 months later...
  • 1 year later...
I do this at work, bit scary at first but it works.... If they're really bad, sandpaper first.... work your way up through the grades of wet and dry to 1500 or 2000.... then silicone free polish. Takes about an hour a pair, even on the worst condition lights.
Try using silvo from Coles or woolies. about $8 for a can that will last you two lifetimes.
Using a cotton cloth... put some on it then rub in small circles with pressure.
Then buff off with a clean cotton rag.
Finally, to help protect the finish... add some car polish and then polish off as per usual.
This will cure the fading/yellowing problem but not the cracking.
Plastic gets old and doesn't like the sun... it cant be helped.
Edited by negoshi8or
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
