Well well well its time for some headaches.
The car was running but when i started it sounded like a V8 car like it was misfiring. Suddenly it stopped 1 hour later and was souding like an RB after 1 hour of driving.
Then a few days later after driving it it was having problems starting it.. slowly slowly getting worse on starting it so i had to get it push started to get it running.
I was running low on fuel b4 it started playing up? Not sure if this will effect it.
I instantly thought my plugs where dead since they looks nasty and where very old. I replaced the plugs just then with BCP6E plugs NGK (x6) and the car still wont start.
The coil pack plugs are all cracked and half missing plastic on them. Why isnt the car starting? I havnt tried to push start it yet as i dont see it making a differnce? Is it the plugs really? but its still not starting? If anyone knows what happend to this beutiful 5spd RB20DET Cefiro please let me know.
John Cambell
https://www.sau.com.au/forums/topic/69355-car-not-starting-now-rb20det/
its too csotly too fix, you can buy another.
Its on the front of your CAM belt cover... the round silver thing.
thats not 100% what it is though, just a likely choice.
a workshop you need to go to i think
What are they worth to buy from wreckers ( used ).
Do R33 ,R34 ones fit? GTR also?
Thanks
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
