An interesting read...
http://www.importbuilders.com/pistoncomparo.html
I went with wiseco as they appear to be quite common and proven in the rb30's.
It also made a big difference that my engine builder swore by them. lol
They also happen to be one of the lightest pistons.
But that said.. Wiseco and Arias are both very good pistons.
CP's and some of these others are also apparently good, I've personally heard on set of CP's that were very noisy in a CA18DET.
My engine builder uses these alot, on many different street & race prepped 4-&6cyl cars (including Skylines). I did a little research on these, didn't find anything to worry about.
2BNVS - My builder got these in Lilydale, Victoria. He paid $1100.00. I did a search in Google & and there is heaps of info on them & they should be available in NSW.
I was all for the Arias, cost wasn't really an issue, as they simular in price, but I was convinced by my engineer (had a first hand look at some of the engines he has built) & by a few people using these pistons & who had their engines built at the same place. Let's hope I made the right choice.
Mahle are pretty good pistons, as long as you get the clearances to the spec sheet provided everything will be fine.
CP's are very fine pistons, they require little clearances (much less than Arias or Venolia). Due to the low expansion/clearances required, if they were put in a motor and spec'd to "normal" forged pistons you'll have excessive gaps, and probably get a bit of piston slap.. as well as blow by and wear. I'd be pretty concerned/annoyed if I was the owner of that CA18.
Interestering you say that.
The builder is apparently the 'best' RB builder in SA, When choosing a builder for mine I threw a few questions at him and honestly had my doubts. So I went to some one else. :(
id stick with well known stuff for anything relating to a motor thats getting a forged bottom end.
no pint risking to save a few $$ and then be stumped later.
Arias all the way
Mahle is a lot better known around the world then Arias mate, thank Porsche for that. Infact Arias are probably cheaper.
i was reffering to use in Skylines.
each piston would be different for the respective motor.
many RB's run arias
6 out of 10 Formula 1 teams use Mahle pistons. Thats a fair indication of their quality. Mahle is one of the worlds biggest piston manufacturers and supply F1, IRL, Nascar, WRC, V8 supercars etc.. as well as Mercedes, BMW, Porsche, Ferrari, GM, Ford etc.. They also own Cosworth Technology and ACL piston products.
They are a little dearer than most other pistons but quality costs money. Look at their F1 pistons, 19 500RPM, 15 000G when they change direction at that RPM and they stay together, thats a fair indication that they have it right.
Attached is a pic of their box-n-box design.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
