Okay, time to do some cleaning up.
Standard parts from R33 S1:
Factory intercooler - $75.00.
Front bumper support, cut for FMIC - $200.00.
Front indicator casings - $150.00.
Side indicator covers - $40.00.
Other parts:
Pioneer HU, model DEH P3350 complete with box and instructions - eBay.
HKS oil catch can - $100.00.
Momo steering wheel - $100.00.
All parts are located in South Australia and are available for pick-up / inspection. I am willing to post or freight all parts interstate.
Please do not discuss prices in this thread, as per the rules. I am open to serious offers.
Pictures are uploading now and will be added shortly.
PM me for further information. I will respond to PMs faster than I will respond to replies posted in this thread.
The Pioneer HU is the only item I bought first hand, so I'm not 100% sure re. the oil catch can and the steering wheel. How can I find out?
The oil catch can did have a HKS sticker on it, but I pulled it off. It now has no markings whatsoever.
yeh im not sure about the catch can but i dont think its a momo wheel hey, do correct me if im wrong but ive never seen one like that:)
interested in the catch can but, who knows how you would find out wat it is though???
The Pioneer DEH P3350 head unit is now for sale on eBay starting at fifty cents with no reserve.
If any of you are interested: Click to eBay, register if you do not have an account, then search for PIONEER DEH P3550.
I will probably list some of the other items from my first post on eBay in the next couple of weeks, so keep an eye out.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
