bump
Hey pred, ive done this to my gtst, i bought the bracket new from nissan, and was able to modify and mount the original latch/catch whatever to work with the grill/bonnet etc.
Its the piece the horns mount to and the latch and shit. I dont think it was that expensive. trade helps :P
Mick
Its the piece the horns mount to and the latch and shit. I dont think it was that expensive. trade helps :rofl:
Mick
Can you take some photos, or write up a how to for me? Seems to be a simple job, but i need to see how its done so i can do mine.....
I did it earlier today.. no new latch required..
basically it involves just unscrewing all the bolts and moving things around a bit..
For the main bracket the latch attaches to (it bolts to radiator support with 2x bolts).. you will need some spacers/washers behind and before where it screws into the support.. to pull it back a bit.. then some longer bolts. Basically you want to move it back 1cm or so.
Then you will need to push it "up" by undoing the bottom bolt and pushing the whole lot up. Then reattaching the bolt so that the bracket is sitting on the top of that bolt.
You may have to play with a couple of the latch bolts, and it has some movement built in, so get it in the right place then tighten.
There is probably different ways to work it, but mine latches very nicely now.
LEGEND!!!!!!!!!!!!!!!!!!!!!!!!
Wouldnt happen to have a few pics so help explain. What you have said is very concise and helpful, and im sure i know what you mean, but photos helps ding bats like me work on the car the morning after the night out:)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
