Even though I took the easy way out and bought a turbo front cut, its good to see that you have set your mind to turbocharging the existing engine.
My only advice is don't do it on the cheap and plan for things to go wrong. If you don't it could be a project you wish you never undertook.
Good luck!!!
Brett
cheers everyone,
Yeah ive already bought the turbo, intercooler and exhaust manifold (and heatshield). I have a HKS turbo timer (type 1), safcII & Apexi EL boost gauge on the way.
I dont particularly want to just exchange with rb25det.
wanna see what the rb25de can do first.
even if she is just a fair bit quicker than what she is now (ive been told i should be able to gain about an extra 100rwhp out of her once its all done. - which wont be too bad, cus im running 166 at the moment)
I also have lined up gtst front discs and calipers, injectors, and ecu, and am thinking about just getting stock intake pipe and bov for now.
Probably looking at late may maybe sooner before she goes into the shop
cheers everyone,
Also look into getting some standard turbo shocks/springs for the front as I'm pretty sure they're different between the turbo and non-turbo variants. If the spring rates currently in your car are not sufficient, you will not get it engineered.
:D
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
