My uncle runs a farm/vineyard in the yarra valley where we often go for a weekend away...
this week theyre filming a portion of Charlottes Web there... for 30 seconds of film it takes 1 week to shoot :D something like 120 people... 4 semi trailors and a lot of vans.
theyre bringing magpies and sheep (their farm is a cattle farm as well as a vineyard) to use in the shots which will only be for 30 seconds of film time :D
they have to cut some branches down (well get my uncle to) to get the trailors in and they said that for every branch he has to cut for them to get through theywill give him a slab ;)
There will also be a 24 hour food caravan open to everyone to eat so if he gets hungry they said to come up and have a feed.
None of the stars will be there or anything cause its mainly a scenery shoot as well as a "chase scene" and the lead up to the farm down the driveway which will look pretty much.... like this
414IMG_00061.JPG - i took this while we went up in spring
This was taken from a spot near a dam where they will be filming...
414IMG_0018.JPG - taken on the same day
we're thinking of going up this week to watch (and help my uncle out with all this free beer hes getting lol) ;)
https://www.sau.com.au/forums/topic/69480-filming-of-charlottes-web/
lol yeah not just finger food either... full catering staff
Yuck Fou. Oh ni you know you got a mention in Speed mag "Not to be outdone, D1NZ driver Jarius Whareau drove the RB26-powered Cefiro of Nikora Terrill with some aplomb." Mr lar de dar. To bad you havent got it any more would make a good shot in a scene like that. The only thing you'll be shooting though is the sau guys trying to get onto the set for some of that free food and BEER!. :usuck: :headshot:
lol yeah wont post up the location for obvious reasons... yeah i have that speed mag :P i was going to take the car there for a shoot but its too far away to drive with no rego.
when i get another car i'll organise a cruise up there... but hen the actuall hotel and stuff are built and they have wine tasting on... its awesome up there... love going out there and staying over (even when i get put thru a barbed wire fence on a motorbike.)
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
