  • 3 weeks later...
  • Replies 119
Posted Images
SK where did you get your intercooler from. Do you or does anyone know where to get them from, or how I could get one?
I bought mine from the SAU for sale section for reasonable price. They come up pretty regularly, have your money ready and move swiftly.:cheers:
if anyone is interested in going this route with their Stagea, i have a Trust sidemount for sale. they are larger than the R34IC's but bolt up just as easily.
i will be shipping it after next week to the highest bidder.
Trust IC
Damn it, I thoguht that sydneykid had put up the results?
Sydneykid, any news mate? we're all dieing here waiting.
Thanks Mate
Sorry, but it is racing season, Philip Island last weekend, Oran Park this weekend, Darwin in 2 weeks, Sandown 2 weeks after that and back to Oran Park the next week. That's 5 race meetings in 7 weeks in 3 states.
The Stagea stuff just has to wait in line. Plus I have to test the Magic Cat (for emmisions) and to do that I need to put the 3.25" exhaust on. I am aiming for emmisions testing this week and dyno tuning next week before we go to Darwin. But it is tight and we have no room for issues.
:rofl:
SK as you are coming to Dwn and me living here let me know if ya want to catch up. I will be pit crewing for one of the local HQ drivers (my boss). so if you need a hand for running about let me know as I am on hoildays with my son who is up from Brissy.
Cheers ICE
Cheers ICE
Thanks for the invite, I may not be going up though. We have a new ECU package and I think I will have to send the engine tuner up instead. There are no spare seats on the plane, so it's him or me. Will know for sure later this week.:rofl:
OK I have just installed my GTT intercooler and was wondering what PSI people are running with this bigger one?
Before with my stock IC my boost was maxing at 8 PSI, now with the R34 GTT IC I am maxing out at 10 PSI. only mods are exhuast and air intake no boost controller of any sort.
So when I put my manual boost controller in is it safe to run 12PSI or stay at 10 or what do people recomend with a stock turbo?
I wouldnt think the intercooler alone would change your boost level by that much. I noticed a boost increase of just above 0.5psi. The only reason it will increase boost if your car is stock is because of the solenoid that bleeds air above 4500rpm. The amount it bleeds allows boost to go from 5psi to about 8psi above 4500rpm. As you are removing a restriction you will most likely have more air supply and it would need to bleed off a bit more ar to keep the pressure at 8psi which it doesn't so you get a little more. I still would think that you would be lucky to get more than 1psi if the setup is stock!
I think the consensus is 10psi is a lot safer. I have problems at around 10psi with Rich and retard so on stock ECU I think going above 9/10psi is pointless unless you use something like a Fuel Adjuster or powerFC. I have yet to determined if my problem is coil packs or just the ECU protecting things.
Mostly when I floor it the psi hits 6 and still does but when the car dropes down a gear or 2 and really gets reving it sorta leaks up to the 8psi and now 10psi, more so around and coming out of corners. I was very suprised to see it hit 10 as well.
I run 0.7 bar (10.3 psi) with the DFA tuned, but it wouldn't run more than 8 psi before the ECU R&R kicked in. That's with zero mechanical upgrades, std exhaust, inlet, timing etc. :rofl:
Hey SK. Interested to read you only got 8psi before R&R.
I am having some trouble with the car hesitating a bit above about 8psi. Especially on cold nights. The car sort of runs a little rough as you rev it out and feels like it isn't going as hard at 10psi compared to say 7psi. Only when you come on boost. If you use part throttle to moderate the boost it feels like it is accelerating harder
I don't think it is the coils, I've now swapped them for others.
Just suprised as a lot of other people are running up to 12psi and not getting this kind of thing...
So I need PFC or DFA??
Thanks
Car is R33 RB25det manual series1
Thanks
As I previously posted the Stagea ECU is a bit smarter than the average. It seems to be halfway between the R34GTT and R33GTST ECU's, with its protection strategy anyway. Plus ours has a standard exhaust (and everything else at the time), which complicates the tuning.
I have seen R33's with slight R&R at 7 psi, it depends on the mods and the tune. Strange things like smaller plug gaps and slightly advanced ignition timing help. So I always try them before I get into the more serious stuff.
For a manual I would ALWAYS go for the Power FC, far too many compromises with the piggy backs. But the DFA for ~$80 is a great low cost alternative if the budget is tight.
:mad:
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
