  • 3 weeks later...
  • Replies 119
Posted Images
SK where did you get your intercooler from. Do you or does anyone know where to get them from, or how I could get one?
I bought mine from the SAU for sale section for reasonable price. They come up pretty regularly, have your money ready and move swiftly.:cheers:
if anyone is interested in going this route with their Stagea, i have a Trust sidemount for sale. they are larger than the R34IC's but bolt up just as easily.
i will be shipping it after next week to the highest bidder.
Trust IC
Damn it, I thoguht that sydneykid had put up the results?
Sydneykid, any news mate? we're all dieing here waiting.
Thanks Mate
Sorry, but it is racing season, Philip Island last weekend, Oran Park this weekend, Darwin in 2 weeks, Sandown 2 weeks after that and back to Oran Park the next week. That's 5 race meetings in 7 weeks in 3 states.
The Stagea stuff just has to wait in line. Plus I have to test the Magic Cat (for emmisions) and to do that I need to put the 3.25" exhaust on. I am aiming for emmisions testing this week and dyno tuning next week before we go to Darwin. But it is tight and we have no room for issues.
:rofl:
SK as you are coming to Dwn and me living here let me know if ya want to catch up. I will be pit crewing for one of the local HQ drivers (my boss). so if you need a hand for running about let me know as I am on hoildays with my son who is up from Brissy.
Cheers ICE
Cheers ICE
Thanks for the invite, I may not be going up though. We have a new ECU package and I think I will have to send the engine tuner up instead. There are no spare seats on the plane, so it's him or me. Will know for sure later this week.:rofl:
OK I have just installed my GTT intercooler and was wondering what PSI people are running with this bigger one?
Before with my stock IC my boost was maxing at 8 PSI, now with the R34 GTT IC I am maxing out at 10 PSI. only mods are exhuast and air intake no boost controller of any sort.
So when I put my manual boost controller in is it safe to run 12PSI or stay at 10 or what do people recomend with a stock turbo?
I wouldnt think the intercooler alone would change your boost level by that much. I noticed a boost increase of just above 0.5psi. The only reason it will increase boost if your car is stock is because of the solenoid that bleeds air above 4500rpm. The amount it bleeds allows boost to go from 5psi to about 8psi above 4500rpm. As you are removing a restriction you will most likely have more air supply and it would need to bleed off a bit more ar to keep the pressure at 8psi which it doesn't so you get a little more. I still would think that you would be lucky to get more than 1psi if the setup is stock!
I think the consensus is 10psi is a lot safer. I have problems at around 10psi with Rich and retard so on stock ECU I think going above 9/10psi is pointless unless you use something like a Fuel Adjuster or powerFC. I have yet to determined if my problem is coil packs or just the ECU protecting things.
Mostly when I floor it the psi hits 6 and still does but when the car dropes down a gear or 2 and really gets reving it sorta leaks up to the 8psi and now 10psi, more so around and coming out of corners. I was very suprised to see it hit 10 as well.
I run 0.7 bar (10.3 psi) with the DFA tuned, but it wouldn't run more than 8 psi before the ECU R&R kicked in. That's with zero mechanical upgrades, std exhaust, inlet, timing etc. :rofl:
Hey SK. Interested to read you only got 8psi before R&R.
I am having some trouble with the car hesitating a bit above about 8psi. Especially on cold nights. The car sort of runs a little rough as you rev it out and feels like it isn't going as hard at 10psi compared to say 7psi. Only when you come on boost. If you use part throttle to moderate the boost it feels like it is accelerating harder
I don't think it is the coils, I've now swapped them for others.
Just suprised as a lot of other people are running up to 12psi and not getting this kind of thing...
So I need PFC or DFA??
Thanks
Car is R33 RB25det manual series1
Thanks
As I previously posted the Stagea ECU is a bit smarter than the average. It seems to be halfway between the R34GTT and R33GTST ECU's, with its protection strategy anyway. Plus ours has a standard exhaust (and everything else at the time), which complicates the tuning.
I have seen R33's with slight R&R at 7 psi, it depends on the mods and the tune. Strange things like smaller plug gaps and slightly advanced ignition timing help. So I always try them before I get into the more serious stuff.
For a manual I would ALWAYS go for the Power FC, far too many compromises with the piggy backs. But the DFA for ~$80 is a great low cost alternative if the budget is tight.
:mad:
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
