No where near as much as my mates 32gtr that has gone through about 5 motor and different turbo applications to achieve a low 10 sec pass.
Spend 5k on an XR6T and you could run 10 sec pass.
380rwkw
Auto
Diff gears
slicks
=10 sec pass
i spent 2 k on mine to achieve from 195rwkw to 300rwkw.
Also to the arguement that they are no good at track work,If you seen one set with the right springs and a manual trans and good driver they can mix it with most cars.
2K for 300rwkw? Gees that's hard to believe. An APS phase 2 kit cost at least 5K and they claim it delievers 330kw at the fly. So i'm guessing you'll get 270rwkw from that.
There's a guy on XR6T forum that does 11.5 1/4 miles and I'm sure he's spent at least 5K doing it up so 5K for 10 sec passes is hard to believe.
Don't you need to change injectors(1K+)
edit+tune (1K+)
There's already 2K.
But then again you are doing everything yourself so you are saving a fair bit of money whereas most other people just give the car to someone else for them to do the work. That's where the $$$ come into play.
  • Replies 129
Trust me.That guy is craig.His car is a weapon.As for mine it is full APS Phase 2 running around 360fwkw.
There is so many was to mod a T now it doesnt cost much money.
I just went to the airpowersystems site. Phase 2 is meant to be 330fwkw.
You must of bought the aps kit 2nd hand because 2K wont even buy you the phase 1 kit.
edit+tune (1K+)
There's already 2K.
There is many Unichip computers on the market,Injectors are getting cheap to source second hand,The auto just needs a shift module fitted"$60" and a oil cooler to be a super positive shift and the exhaust isnt dear if you know what combo to run.
I am with FIST Performance in Brissy.APS 330fwkw claim is only a guideline and all cars perform to how they are tuned.Im running 11psi with stock intercooler.My injectors are running about 90% duty cycle.I could easily run 14 psi and up some more fuel with a $800 intercooler and achieve 360rwkw.If i wont more i up the injectors again.I then regear the final ratio with a MK 2 final drive out of a manual with some 17 inch rims and with the right conditons and a set of borrowed slicks 10 sec Qauters are there.
Check out APS 10.98 Phase 3 car
there is many cheap piggy back cpu conversions around so sourcing them with injectors and exhausts and intercoolers isnt hard or exspensive.The turbo is rated to 650 hp or close to it.So the XR6T is a tunable weapon and will more so be in the future as manufactures of parts jump at each other for the competition.
I work with all makes including alot of nissan skylines,200 sx,supras and anything else that has a turbo.
  • 1 month later...
  • 2 months later...
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
