has anyone heard of a hall effect switch?
If so, i have a problem with my daily driven car, a holden calibra.
It will start fine, then for no reason the next time i go to start it just kicks over but nothing. Seems like im not getting a spark when it decides not to start.
I got into the ecu which says the hall effect switch is getting high voltage
https://www.sau.com.au/forums/topic/69518-hall-effect-switch/
its a Calibra, that's the problem.
These have a pretty bad rep. Hall effect? never heard of it in mechanical terms... could be a bad igniter or simply your immobiliser playing up?
Sounds silly, but immobilisers sometimes cause more problems then you'd beleive.
Some immobilisers allow the car to turn over but not actually start, others stop everything.
Hall effect switch = a switch activated by a magnet, basically a chip version of a reed switch.
Not sure how the engine management in a Calibra works, but it could be something along the lines of the crank angle sensor (CAS) in a Skyline - the hall effect switch might detect rotation of the crank so that it know when to fire the injectors, spark plugs etc. If this isn't giving the correct signal the engine don't go!
Absolutely no idea where you'd find it though in a Calibra!
yeah its time to say goodbye i think.
I would like to fix the problem first so the new owner doesnt have the same problem.
If i can figure out why it has high voltage i will be able to fix the problem.
thanks guys!
High voltage probably implies that its state isn't changing - ie the signal from it should pulse in response to the magnet attached to the crank or cam passing by it. At a guess either the sensor itself is dead, or the activating magnet is not working properly.
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
