has anyone heard of a hall effect switch?
If so, i have a problem with my daily driven car, a holden calibra.
It will start fine, then for no reason the next time i go to start it just kicks over but nothing. Seems like im not getting a spark when it decides not to start.
I got into the ecu which says the hall effect switch is getting high voltage
https://www.sau.com.au/forums/topic/69518-hall-effect-switch/
its a Calibra, that's the problem.
These have a pretty bad rep. Hall effect? never heard of it in mechanical terms... could be a bad igniter or simply your immobiliser playing up?
Sounds silly, but immobilisers sometimes cause more problems then you'd beleive.
Some immobilisers allow the car to turn over but not actually start, others stop everything.
Hall effect switch = a switch activated by a magnet, basically a chip version of a reed switch.
Not sure how the engine management in a Calibra works, but it could be something along the lines of the crank angle sensor (CAS) in a Skyline - the hall effect switch might detect rotation of the crank so that it know when to fire the injectors, spark plugs etc. If this isn't giving the correct signal the engine don't go!
Absolutely no idea where you'd find it though in a Calibra!
yeah its time to say goodbye i think.
I would like to fix the problem first so the new owner doesnt have the same problem.
If i can figure out why it has high voltage i will be able to fix the problem.
thanks guys!
High voltage probably implies that its state isn't changing - ie the signal from it should pulse in response to the magnet attached to the crank or cam passing by it. At a guess either the sensor itself is dead, or the activating magnet is not working properly.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
