G'day,
Sorry to be a pain, but does anyone know how to set the clock on an Addzest ADX5455 CD player?
I've checked out the Clarion website (the associated company of Addzest) for a manual, but their instructions for similiar units don't work. :)
Any assistance would be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/6952-addzest-clock-setting/
Guest SPOOLIN
I have the ADX8455 but my manual is in Japanese, so ill do my best *dodgy* translation.
1] push adj button.
2] push up or down on the volume wheel( round thing) till "clock" is displayed.
3] push play/pause/ent button(middle of the round thing).
4] move left or right on the volume wheel.
5] move up and down on the volume wheel.
6] repeat steps 4 & 5
7] push play/ent button.
8] push adj button.
hope this helps
Lee
  • 7 months later...
Guest Mr Benz
Did you ever get the time set on your ADDZEST? Do you still have it? If so here's how you set it.
1. Turn the ignition to ACC position
2. Push the DISPLAY button until the time shows up
3. When you get to the time press and hold the the BAND and #4 buttons at the same time
4. Watch the display where it has the 4 arrows...you should see the yellow writing disappear and the "HOURS" start to blink on the time
5. Adjust the hours up or down by pushing the 4-way button either up or down
6. Push the 4-way button to the right or left and the minutes should start blinking; repeat the up or down like you did for the hours
7. When you have the time set, push the BAND button again and you're done!
If you have any questions please reply.
Wendell aka Mr Benz
You can have your webmaster remove me now, I just wanted to answer your question. (I stumbled upon it while searching GOOGLE for the same problem you were having)
  • 4 weeks later...
hey guys,
there is this guy selling an Addzest VAX787A screen and cassete deck.
not sure if there is an Fm expander cause he says there is fuzz but when he pulls out the deck, the anttanae wasnt connected.
so anyways, how much does an fm expander cost anyways?
what does the screen do?
it doesnt come witih a changer and there is another guy sellin an addzest changer.
Can i safely assume that any addzest changer will work with the deck as it has a changer control saying disc there and etc.
what is the screen for anwyays?
cant read japanese on the addzest sites anyways and there isnt one in english!
:D
thanks guys
sorry to steal yr thread tho...
  • 7 months later...
  • 3 weeks later...
Ahh.. Don't you just love those double DIN aftermarket japanese head units that come installed in alot of skylines along with all the other goodies... I have a Addzest MAX-4555z GPS/TV/CD/MD, touch screen motorized head unit, with CD stacker & Addzest NAX-010VD (GPS Car Navigation & DVD-VIDEO) system. It's very cool.
I still havent discovered all the features of the unit, so many configuration options. It has digital sound processing, graphic EQ, full screen graphics, etc. Unfortunately the DVD player is not multi/region 4, and the TV tuner is NTSC only but I still love it :(
If anyone knows a specialist installer or car audio workshop who can convert the DVD player to multi region PAL, and convert the TV tuner box to receive australian TV frequencies let me know.
G'day,
I've checked out the Clarion website (the associated company of Addzest) for a manual, but their instructions for similiar units don't work.   :D
Thanks.
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
