depends on the complier but they usually will either modify your xenons to become H1 halogens (waste of good xenons) or remove the headlight and put some other branded headlight in (i forgot the brand)
to save your xenons, try to source / borrow halogens and get it compiled.. afterwards, just replace them
imo, xenons are WAY brighter and look "cool".. they are also cool temperature wise
my halogens look ugly and not that great, esp in the rain
I had mine replaced to halogens when i took delivery of the car....headlamps still had the xenon word in it...but the bulbs were jst ur normal halogen H1 type. Got my xenons put back in about a week later and holy shit...u can definately tell the difference! Its white as compared to the yellow beams from a halogen. Comparable to the white flourescent tubes for homes I guess to your normal halogen yellow bulbs. When u first turn them on they flicker for like 1/2 a sec then takes about 10 secs to reach full brightness. Definately make a difference on road and looks cool too :P
mine had the headlights replaced,, to halogen headlights,, wires were cut and everything,, grrr!!,, they don't look as good as the xenon headlights,, looks more like the ford headlights
so i just chucked in some HID's and now they are brighter then factory xenon's
  • 2 months later...
How easy are they to replace??... will be complying my 34 in around a month
and will def. want to keep the xenons.
i bet they will have to take them out for compliance though. damn ADR
any modifications to unit required? please explain for the xenon ignorant :)
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
