bump, come on, somebody with a 32/33 in melbourne must want these!
I have seen plenty of 33's with stock wheels, how about some nice [and wide] Jap ones???
:P
  • Replies 91
any idea how much it costs to send them to sydney?
Approx $130 - I bought some rims from a guy in Syd and I think he said it was $127, these were 18 inch w tyres so possibly heavier which is usually more...
I'm interested,
With the gutter marks, any close up pic that you can post?
Also has any of the wheels got slight buckle in it (e.g. due to hitting the kerb)?
