17 inch Yokohama AVS wheels + tyres suit R33 GTST / R34 GTT
looking for a 60-63 mm / 2 1/2 diameter T pipe like attached with a BOV flange that has a 87 mm center to center spread. is there specific term used to describe this size of BOV mounting? I find some listed as GD, RS ,FV,RZ type...what do each of these type specify?
I did read it all, but been restoring and fabricating classic custom award winning vehicles for 30 years, so I don't think some wiring and a cable will be a problem. doubt a retune will be needed, not with these changes, and not necessary as essentially everything will be essentially stock. just changing the location of the throttle body, wont make much of a difference, engine and ecu wont know the difference, still will get air, spark, compression, fuel, and sensor readings. All will still functions the same as same size and type of components used. additionally I am in the US, so in a few years if someone around here gets experience with tuning these cars properly and or I can obtain the software, programs etc. and experience, then maybe someday a tune will be done, to optimize performance.
10-4, that's what I found, wanted confirmation, too many place sell stuff claiming its right and half the time its not, I order them up ,thanks
might as well go e-throttle -
FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
