we're talking about a guy trying to do up his GTR and using EBC and SAFC when he should do it properly and buy a FC and remove the restrictor. Then as funds permit buy a EBC if needs be. I have removed my restrictor had PFC tuned properly and never had a problem. Put an accurate guage on the boost level and showed 1.02Bar from 4500rpm - 7200rpm. Thats pretty good in my books and even better the restrictor removal cost me nothing.
  • Replies 57
Originally posted by GTR98
we're talking about a guy trying to do up his GTR and using EBC and SAFC when he should do it properly and buy a FC and remove the restrictor. ย Then as funds permit buy a EBC if needs be. ย I have removed my restrictor had PFC tuned properly and never had a problem. ย Put an accurate guage on the boost level and showed 1.02Bar from 4500rpm - 7200rpm. ย Thats pretty good in my books and even better the restrictor removal cost me nothing.
gtr98,
nobodys disagreeing with you,but if were talking about wasting money,u spent money on a power fc u didnt need if ur only running 1 bar.
If i ever want to do more mods one day then i dont have to sell my SAFC and buy a PFC. I havent butchered my wiring and if i ever want to return the car to standard then i can do it in about 5 mins and im sure i can sell a PFC a lot easier than a SAFC.
Im not going to get into a slagging match with you mate, so i will leave it there. Each to their own. You own a GTR built well, reliable, and great fun to drive. Dont turn it into a piece of crap like so many out there. Do it properly once and never have a problem again.
Cheers
If i ever want to do more mods one day then i dont have to sell my SAFC and buy a PFC. ย I havent butchered my wiring and if i ever want to return the car to standard then i can do it in about 5 mins and im sure i can sell a PFC a lot easier than a SAFC.
Im not going to get into a slagging match with you mate, so i will leave it there. Each to their own. ย You own a GTR built well, reliable, and great fun to drive. ย Dont turn it into a piece of crap like so many out there. ย Do it properly once and never have a problem again. ย
Cheers
dood wasnt trying to have a slanging match with you,i have 2 gtrs both with power fc,the point i was making was u dont need a pfc or an afc if ur only running 1 bar,standard ecu is more than capable of 1 bar,theres a number of gtrs running around with 1 bar making 240kw plus at the wheels running standard ecu
And with our crapy fuels one day those motors will go POP.
rubbish.
if the tuner knows what he is doing,will run every bit aswell as a pfc car.
i know of atleast 6 or 7 cars that are running 240plus without a problem and running deep into the 11s
Mine is one of those cars. There are many others that I know of who have run this way for some time now without any dramas. At this range I have seen every bit as much Horse out of a car with standard comp as Power fc. Once you go higher than this then sure you need a PFC, but you also need injectors, different turbos etc. It is a big step, but if you are not looking to go higher then this then in my opinion from what I have seen on the dyno there is no benefit from the power fc.
Just in the guy you choose to do the tuning.
vspecv,
Today is the big day. Tick tock. Good luck. (and I want a ride :D )
Mick.
Originally posted by Mick Trainer
Mine is one of those cars. ย There are many others that I know of who have run this way for some time now without any dramas. ย At this range I have seen every bit as much Horse out of a car with standard comp as Power fc. ย Once you go higher than this then sure you need a PFC, but you also need injectors, different turbos etc. ย It is a big step, but if you are not looking to go higher then this then in my opinion from what I have seen on the dyno there is no benefit from the power fc. ย
vspecv,
Today is the big day. ย Tick tock. ย Good luck. ย (and I want a ride :D )
Mick.
yep todays the day,its finished and ready to pickup,rebuild no2 is complete.
I'm a newby here so have a few questions relating to info in this thread, my apologies if it has been covered already.
where is this restrivtor you speak of?
how do you remove it?
does the factory ecu then account for the change in boost or do you have to get the car dyno'd/tuned?
i thought the r33 ecu was not programmable, therefore what can be achieved with an r33 by having it dyno'd?
thanks
Steve
Guest turbogtst
I am running modified standard cam gears set at 6 degrees advanced on the inlet and 6 degrees retarded on the exhaust, a rechipped R32 GTR ecu in my R33 GTR, 550cc injectors, stock turbo's, cat back exhaust with no cat, making 1.2 bar boost at 3800 rpm. I have had a power fc no better than a rechipped ecu same power results 250 kw at the wheels.
Y0880 - On the GTR you can run up to 1.4 but not if you intend to keep your turbos for a long time. I'm running 1 bar and have been safely for a while now and I think anything between 1bar to 1.4 is risky with the standard ceramic wheel.... especially in summer.
71LLA:
It is a small metalic ring that sits inside the vacuum hose on the way to the solenoid which restricts your car to the boost it runs stock. Hence the name
You pull off the vacuum pipe, and get pliers or tweezers and pull it out and reattach the vacuum pipe. Alternatively cut the part the restrictor is in (you can feel it).. and reattach the pipe.
The boost is not affected by the ECU here and there is no boost cut at this level... when you remove the restrcitor you get instant one bar boost.
400HP
You pull off the vacuum pipe, and get pliers or tweezers and pull it out and reattach the vacuum pipe. Alternatively cut the part the restrictor is in (you can feel it).. and reattach the pipe. ย
Thanks for that, can you give me a clue on where *exactly* I can find this vacuum pipe? Seems to be lots of hoses under this bonnet.
And to confirm, once it's out that is it? No need to have anything done to the R33 ECU? Won't it run lean?
My digi cam is f*cked so I can't take a photo. Basically if you look on the left side of your car above and to the left of the plenum there is like a little gold cylinder about 2cm x 4cm. This is the solenoid. There will be two vacuum hoses going to this. One that goes from the bottom of it and one that goes from the side. If you feel around and squeeze the hose within the first 10 cm of the one that comes from the side you'll feel a part which has a small metal bit. Thats what yoiu need to remove.
Sorry this is the best descreiption I have of it.
Thats right. Remove... done.
  • 3 weeks later...
alright people.....I'm seriously confused. I have the car booked in to get the cam gears done but I am stoked to which brand to get. I rang Sub-Zero in Q.L.D yesterday and they advised me not to get the HKS gears because they only last 25 000kms....wtf????
My number 1 problem is that I have people telling me that the HKS gears last forever and that they are really good....but on the other hand I have people telling me not to use them because they are really really shit.
What should I do?
Sorry to be a pain in the arse but I'm not in favour of buying Cam gears and them lasting only 25,000 kms. I need your opinions and info!!
Thanks again
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
