Hi all,
Just a question, why are manual R34 GTT's still so expensive? They are still around the low to high 30's mark and have been like this for some time. Most of these are 98 models also. The autos and sedans are much cheaper.
I remember when R33's were at this age they weren't this expensive.
Have import laws changed so that these cars are now more expensive to comply? Whats the GO?
https://www.sau.com.au/forums/topic/69591-why-are-r34s-so-expensive/
depends on the kind of r34, i picked up a 1998 r34 gt-t sedan semi-auto 42000km in excellent condition, completely stock for $25g (wholesalers price). The manuals and coupes go for between $31g and $38g.
yeah, this is good news for r34 owners as the price seem to be the same/higher as when i got mine back 5-6 months ago
manual r34 are goin for mid/high 30s whilst tips are goin for low/mid 30s
this is for private sale tho .. expect to add 3-4k for dealers
I've seen some semi-auto coupes for mid-high 20s, some sedans for low 20s. I even saw a coupe tiptronic for $27k for a dealer...and then there are some way up in the 30s, it's weird, on a car that relatively new (and most of them are bassically stock) condition shouldn't make up that much of a discrepancy?? Pretty sure at those prices I'd prefer a 33 GTR anyway personally.
I reckon it would be like anything....if you were willing to spend 6 months looking around first and had the cash ready you'd almost certainly find a bargain. Maybe LESS of a bargain with the 34 than other cars cos it's in fair demand, but a bargain nonetheless.
On the last two cars that I bought I looked around for a while beforehand and I wasn't in any hurry to buy - first time I got a car for $3k less than the insurance company rated its market value, and second time about $5-6k less. First time I ended up selling the car for $500 less than I had paid after using it for 2 years.
If you look around for a while you really get familiar with what's selling for how much, cos you can't really know what a good deal is unless you know exactly how much something is *actually* worth versus what the price on it is.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
