^^^^ I'm with not so stupid.
SAFC only does fuel maps (so to speak)
I belive the Chip allows for timing changes as well.
Speak to TOSHI from these forums.
Many people have used him with great results.
Very good pricing too.
PS: 16psi on rb25 turbo hey...
Starts taking bets on how long till it go kaBLAAAMOOO
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1287553
trevvy: please forgive me for hijacking but u just posted what i was goin to post...
can anyone give any insight on a unichip compared to a safc II? both can be had at the same price (roughly). safc can only do fuel whilst unichip can do fuel and timing.. are they worth it ... i want roughly a 15+ kw gain ..
edit: i heard toshi also does a remap/daughterboard for r34? anyone have any experiences? i'm interested as i want to get it tuned by the top secret guy coming to australia mid May
reason why i'm not goin powerfc is due to my car being a tiptronic
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1287555
  JXL said:
this is good i was thinking about getting a SAFC2 real soon but how hard is it to tune??
Have a read of the Jaycar IEBC and DFA thread in the Stagea section, the DFA is pretty similar to the SAFC.:cheers:
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1288607
  Trevvy said:
apparently u can run more boost thru the rb25 turbo on the rb20 because it isnt flowing as much air to create the same boost, big thread on it i will find it tonite
thanx for the prompt replies
Trev
I still wouldn't push it past 1 bar.
1bar on the track would be pushing it though.
I know of a R32 RB25 turbo pushing 14psi that made 190rwkw. :cheers:
Chipped ecu, Blitz SBC-iD EBC, Pod, FMIC, 3" Exhaust.
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1288743
For a street car, go with the chip.
There is not much that cant be altered.
eg.
LEVEL 1: speed cut change/eliminate, rev limit change, boost cut change/eliminate.
LEVEL 2: fuel map adjustment, ignition map adjustment.
LEVEL 3: rpm scale adjustment, load scale adjustment (for higher boost levels).
LEVEL 4: injector size re-scaling, AFM re-sizing.
Its all do-able, if you can fit an eprom!
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1292194
Yes, the injector latency (sometimes called void blast off time) can be adjusted.
This is part of the issue with the 550cc RX7 injectors, the other is they may not be exactly 550cc/min. Hence, the injector setup parameter may need to be further tweeked for 'best fit'. It may take a few trys but do-able.
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1293448
  Amadeo said:
Can the SAFC2 do the following:
1. speed cut change/eliminate
2. rev limit change
3. boost cut change/eliminate.
4. And is it possible to have both the chip and safc2 on board?
Suggestions follow;
1. No
2. No
3. No such thing as "boost cut", there is protection from excessive airflow. AFM voltage benders such as SAFC, DFA. EManage etc can be tuned to lower the AFM voltage signal to the ECU. Hence it doesn't know about the excessive airflow.
4. Yes.
Hope that was of some help:cheers:
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305350
It feels like basically you guy's are saying the SAFC2 is useless, What kinda gains can be had with one does any one hare have some real experiance with them?
What gains/losses have been seen. Cause lets face it they are a much cheaper alternative to aftermarket EM.
( I know that aftermarket EM offers alot more control and tunability but 1500 to 2000 for supply fit and tune, Compared with 500ish you can see why there would be a market for it, ( If there are gains to be had.))
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305448
I have an SAFC2 in my car (series 1 R33) i got my timing and the SAFC2 tuned and only 1 psi boost increase resulted in 36KW at the wheels increase. But to get the SAFC2 running properly without fuel cutting they had to install a FCD.
Take a look at my dyno graph. Note the dyno graph is just to show the increase its not what my car is actually making at the moment. Cheers
https://www.sau.com.au/forums/topic/69595-chip-or-safc/#findComment-1305999
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
