ok, my RB20DET, has blown its head gasket, my friend knows how to fix it, so im not worried abot getting the job done. but i want to know while im doing this, is it worth buying new cam's, and is there anything else i should do to the engine while im there.....im goin to be drifting it, so can anyone suggest what i should do..or where i should take it?????....
https://www.sau.com.au/forums/topic/69621-help-blown-head-gasket/
Coming from an MA70 Supra background i know all too well about the dreaded head gasket and what to do when you blow one.
It's really important that you make sure your head and block are perfectly straight/flat so get them machined otherwise you'll be blowing more headgaskets in no time.
Also, since you've now blown one and need to fix it, why not look at aftermarket metal head gasket options that are available to you, they're infinitely stronger and should you plan on modifying down the track it would be ideal to do it now.
Good head/block prep is crucial when fixing blown head gaskets imo.
