The car is in excellent condition with 107000kms. Am first owner in Australia and car has never given any problems. Also with the car is still a 2.5 year warranty which covers everything except for the body of the car. This I purchased myself for peace of mind and also will for anybody in the future so if the car arises with any problems which I am sure it wont, the warranty will be ther to help. I am trying to sell this car urgently although it is very regretful sale. Have given regular oil changes although they werent necessary. Will be happy to answer any questions. 107000klms.
Extras:
Gab Shocks with adjustable rear
Greddy full auto turbo timer
3" inch cat back exhaust
Tomei Shift knob
Re trimmed doors
Pod Filter
Top of range sony head unit
Kicker 6" inch splits with crossovers and tweeters
400 watt rms 4 channel amp
12" Kicker Sub in ported box
Genuine GTR front bar
http://img207.exs.cx/my.php?loc=img207ℑ=19qi.jpg
http://img207.exs.cx/my.php?loc=img207ℑ=24me.jpg
http://img207.exs.cx/my.php?loc=img207ℑ=31do.jpg
http://img207.exs.cx/my.php?loc=img207ℑ=40vi.jpg
http://img207.exs.cx/my.php?loc=img207ℑ=57kd.jpg
Price: $14,500 wihtout stereo
https://www.sau.com.au/forums/topic/69631-r32-gts-t/
Ask a really stupid question... But why list all the stereo gear, then not give a price including it?
And before mods mod me, Im helping a few mates and doing so research for them of whats about ;)
https://www.sau.com.au/forums/topic/69631-r32-gts-t/#findComment-1288213
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
