  • Replies 50
That may be asking a little too much :headspin:
not at all.
There is a car here in Vic thats been running 550awkw on the RB36/30 and its still gonig strong 2-3years now.
and thats not the most power it can make either :cheers:
I don't think you can make that much power and still have it driving reliably as the more you rev it and the more boost the more strain you have, therefore shortening the engines life.
Also is long term leaving it on the shelf,driving it to work,drags on week nights or a bit of club racing? or some of all of them?
Nispro has built a 26/30 that made a tad over 1000hp.
It's not what you call a daily driver or one to cruise around town, it's more strip oriented.
The work involved in building these kind of engines is mega expensive and time consuming. Nizpro made a stronger custom crank girdle to handle, the list is endless....
I wonder how many times he has had to rebuild it
Think about it 14ltr truck engines produce approx 500hp and you want to put 1000 through 3ltrs and want it to be reliable...... don't think so!!
not one rebuild, you do it right, you wont have a problem.
This is not a once off either. Heaps of other cars here bet belted around the circuit often and are fine
"doubled" -
*have you built any engines - yourself - not a workshop?
*are you an engineer or metallurgist - are you factually stating block strength results of empirical tests or 'seat of the pants' / 'gut feel' type evidence?
*14L truck engines do not produce much power, as they do not operate at high RPM. Note the requirement for trucks is torque to move the mass, not power
*the car R31Nismoid is talking about is empirical / physical evidence that a fully built RB26/31 is capable of long term, high stress (track work) use
It sould to me, like many people here, you are more accustomed to watching DVDs and reading magazines / forums, taking as gospel and regurgitating.
I've witnessed it with my own eyes.
Are we talking about 1000hp on pump fuel here or something more exotic?
I have a SBC on gas and I could never afford to drive it everyday that's for sure. :P
I am a qualified mechanic, and have been out of that for a fair while, I understand that technology changes, but there is still the wear factor & reliability,
and by pushing things well past their "designed power" output i feel that there life expectancy will suffer greatly.
the car has done inexcess of 400km's
And so have many other.
we are talking 20thou, 30thou... cars are still running strong.
Whats so hard to beleive if they are physically there doing it on the track at most track meets each year?
It can, and has been done, and not just once.
If your tuning is right, your servicing resiliant... and you dont have something like a fuel pump fail and starve the engine...
There is no reason why anything cant last years.
    • Seems to be the case mate , still an OK price for a grey import.
    • I’m interested in the carbon diffuser fins and Toshiba MFD screen replacement if they’re still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
