  • Replies 50
That may be asking a little too much :headspin:
not at all.
There is a car here in Vic thats been running 550awkw on the RB36/30 and its still gonig strong 2-3years now.
and thats not the most power it can make either :cheers:
I don't think you can make that much power and still have it driving reliably as the more you rev it and the more boost the more strain you have, therefore shortening the engines life.
Also is long term leaving it on the shelf,driving it to work,drags on week nights or a bit of club racing? or some of all of them?
Nispro has built a 26/30 that made a tad over 1000hp.
It's not what you call a daily driver or one to cruise around town, it's more strip oriented.
The work involved in building these kind of engines is mega expensive and time consuming. Nizpro made a stronger custom crank girdle to handle, the list is endless....
I wonder how many times he has had to rebuild it
Think about it 14ltr truck engines produce approx 500hp and you want to put 1000 through 3ltrs and want it to be reliable...... don't think so!!
not one rebuild, you do it right, you wont have a problem.
This is not a once off either. Heaps of other cars here bet belted around the circuit often and are fine
"doubled" -
*have you built any engines - yourself - not a workshop?
*are you an engineer or metallurgist - are you factually stating block strength results of empirical tests or 'seat of the pants' / 'gut feel' type evidence?
*14L truck engines do not produce much power, as they do not operate at high RPM. Note the requirement for trucks is torque to move the mass, not power
*the car R31Nismoid is talking about is empirical / physical evidence that a fully built RB26/31 is capable of long term, high stress (track work) use
It sould to me, like many people here, you are more accustomed to watching DVDs and reading magazines / forums, taking as gospel and regurgitating.
I've witnessed it with my own eyes.
Are we talking about 1000hp on pump fuel here or something more exotic?
I have a SBC on gas and I could never afford to drive it everyday that's for sure. :P
I am a qualified mechanic, and have been out of that for a fair while, I understand that technology changes, but there is still the wear factor & reliability,
and by pushing things well past their "designed power" output i feel that there life expectancy will suffer greatly.
the car has done inexcess of 400km's
And so have many other.
we are talking 20thou, 30thou... cars are still running strong.
Whats so hard to beleive if they are physically there doing it on the track at most track meets each year?
It can, and has been done, and not just once.
If your tuning is right, your servicing resiliant... and you dont have something like a fuel pump fail and starve the engine...
There is no reason why anything cant last years.
    • I didn't know about induction heaters but checked them out and they look awesome but too pricey for the occasional job like this. And I'm too nervous to take a flame anywhere near there as the petrol tank is so close, although I was intrigued with the crayons suggestion 馃榿 I filled a coke bottle lid with penetrating fluid and raised it on the jack so the nut was submerged in it all night. Then went in with a tiny cold chisel and got it almost to the point of splitting but not quite (I didn't want to damage the bolt threads). Then I hammered a socket back on and gently worked it until I felt movement. And it's off 馃榾
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
