  • Replies 50
Would drilling and tapping slightly thicker cradle bolts make the rb30 cradle any stronger?
the tourqe that is avaliable from the rb30/26 as compared to the rb26 motor is that you will make torque and power earlier on in the rev range so there is no need for it to rev as hard as a rb26.
And the rb25 has less capacity and is a step down from the rb26/30 or rb26 all together in terms of the power that is possible with the stock crank and cradle support.
I am still a neewbie when it comes building motors,so take it easy. :P
  Sydneykid said:
That's an RB30 block with the standard cradle......
:D
Saw you racing on TV at Wakefield. Pretty cool class by the looks of it. On the track you looked a bit radical though. What the hell's going on with your car?
I am still a neewbie when it comes building motors,so take it easy. :devil:
There is not enough width in the main bearing saddle to handle larger diameter bolts. We use ARP studs, stronger than bolts.:D
  Mr_RB25DET said:
Hi guyz !!! Do you know wat's the best turbo setup for RB26/30 for achieving 800hp ?
I am planning to get T04Z ball bearing... Any advise or recommendation ?
T04Z is the way to go
nd4spd is back ... twin t04z
50km old engine run in tune no timing or anything
799.9 rwhp!!
ALOT more to come from it
BK are you basing your opinions on solid facts or what you have read Martin Donnan believes in HPI???!!!!! I have developed a system to adapt the gtr sump to the rb30 motor that if anything would be stronger than the standard way it is done on an rb26. On my own engine I am also running vacuum pump, a custom made girdle strengthner( retaining the stock girdle) and ati are making me a custom billet steel 4 ring harmonic damper.
I hope to achieve out of my own build around 900hp at the engine rev it to about 8200rpm and do it for a while. Nizpro have made well over 1000hp on there rb30/36 but it threw a rod through the block so they only advertsied to what they believed was the highest level safely and that was around 1000hp!!! After having talked with JUN and Veilside believe me any RB making over 1000hp has its fair share of problems, while rb30s have a major harmonic vibration at around 7.500RPM the Rb26 has the same at 9.200RPM and the same factors have to be faced in overcoming this and holding the engine together bearing wise once you start to rev the thing to make power.... You have to remember a rb30 at 7.5K is equal to the volumetric displacement of air as a Rb26 at 9K.... The problems the japs have with making that much power out rb26's is the revs place unbelievable loads on the valvetrain, veilside rebuild everything in the head every time they give there cars with over a 1000hp a full power run....
Mate it can be done but without sound engineering and mechanical knowledge it is really going to cost you an arm and a leg and maybe more, the trick will be finding someone to do it....
This might be stupid and just obvious but with high power engines, if you don't drive them hard, won't they last almost as long as a stock motor?
How's this situation:
Say you're going on a long drive - just take it real easy....... granny driving it
The rest of the time, well..... like you usually do :) or should be doing.
Well after talk to Keir Wilson at drag combat in Perth about std component strength and other issues. The biggest problem you'll will face is block strength in either the std rb26 or rb30 as i would think them quiet similar in strength. The quote that KW told me was that the std rb26 will break about 800hp (and even suggested not to go over 750hp if you wanting it reliable) And before you guys jump up and down yes they might more hp for a while but the thread was about reliable 1000hp and i think KW opinion should hold a bit of weight due to his expirence with this sort of motor.
So if your serious about a reliable big hp motor you will want to look at either GTR N1 GT block (think walled) or maybe the OS Giken 3 litre small motor.
my 2c
pete
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
