Gear Ratios for R33 GTST?
out of interest, the final drive ratio is on the jap chassis plate.
down the bottom:
i.e.
RC43 = 4.3:1
RC41 = 4.1:1
Hope this helps.
out of interest - see below:
Transmissions:
RE4R01A 4 speed auto
RE4R07A 4 speed auto
RE5R01A 5 speed auto
FS5R30A 5 speed manual
FS5W7 5 speed manual GTS
OK, so next question, how to you turn ratios into revs/km/h?
In the R33 manual I have I have the km/hr for auto and manual ... can't remember off the top of my head, but for 1st its something like 55km/hr for manual, but of course that's just the recommended.
If you are really keen I can type them in for auto and manual for u.
Looks like Gizmo already beat me too it!
I wouldn't say they are like redline figures because they're recommended safe limits, probably around 5000rpm. Probably add another 20k/hr in each gear for true redline figures.
Get a speed cut n Nismo's 320km speedo, to get figures for redline speed on 5th gear...
That is if anyone is brave enough to try....
Disclaimer: I do not encourage excessive driving speed nor
dangerous behaviour on public street.
Originally posted by gizmo
As predator666 said from the manual
Shift Lever (Manual Shift)
Check the table on maximum speeds in each gear from 1~4
(Shift to the next gear up well within these speed ranges)
Shift Lever Position    RB20    RB25DE     RB25DET
1                                50        50              55
2                                85        80              100
3                                135      135            145
4                                165      175            180
1                                50        50              55
2                                85        80              100
3                                135      135            145
4                                165      175            180
Thanks Gizmo.
I figured 7000 in 4th was about 180. I don't know about everyone else's speedo, but its about 210 on mine, so my speedo is 17% optimistic!
And meggala, I reakon it would take a hell of a long private road to get a GTS-T to 270:eek:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
