  • Replies 94
The can comes with only one size fittings.
The 15mm or the 12mm hose can both be attached to these fitings with the hose clamps.
I installed mine using 15mm hose(check pics) and didnt have any issues.
recieved mine today also.  anyone know where that threads gone with SK showing various instalation setups like plumb back and stuff??
Heres a link to one of the threads with SK's plumbing options - click here (goto post #24)
:D
same here. i havent fitted mine yet too. dunno where to put it. the mounting bracket on mine sticks out of the can instead of flush like in the pic so i cant bolt it to the side wall where the brake cylinder stopper would fit.
Yeah I noticed that. Just make a bracket out of a little peice of aluminium you can get from the hardware shop.
I haven't put mine in yet because I am having fuel pressure issues and can' turn the boost up yet.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
