Hey guys got 3x17x10" wide rims for sale.
When i bought the car it only had 3 on so sorry bout that but.
10" wide are very expensive and hard to come by.
Perfect for drag or track racing etc. wouldnt be hard to find another if you wanted a set.
the current 2 rear 255's are down to the belts, and the front 235 has 75% tread left
$600 neg
They fit on my 300zx. R33 GTS-T rims fit my zed so i assume they will fit all skylines with the same pattern as R33gtst's..
pick up only.
0405400170 or e2ek1el21@hotmail for MSN or email.
Peace
Matt.
https://www.sau.com.au/forums/topic/69683-fs-17x10wide-mags/
sorry dude i dont have a skyline, your welcome to come try them on for yourself.
Ask doughboy, he may be able to send pics for you
im QLD. gold coast
offset for 300zx is 114.3 and they fit sweet as front and back on the zed.
im QLD. gold coast
I think you mean PCD is 114.3
offsett is distance from the wheel hub to the centre of the rim sorta of a measure of how far the rims wll fit inside the guards
well dont think I can take up that offer anyway since Im in WA ahahha
give us a pm if you're willing to send maybe I'll consider it and a pic on the zed would also help since from memory I think Z32 and R33 GTS-t have very similar offsett on the rears. Just to see how it fits inside the guards
yea my bad, PCD 114.3
probably not going to be worth posting as wheels and tyres are heavy, 30kg in post will be killer! especially to WA
they sat in my gaurds a few cm's but my zeds lowered an inch which makes it worse.
ive had an offer of $350 but im really after $500 guys.
you wont get 10" rims this cheap anywhere. theres $150 worth of tyre on the front rim alone!
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
