Hey guys got 3x17x10" wide rims for sale.
When i bought the car it only had 3 on so sorry bout that but.
10" wide are very expensive and hard to come by.
Perfect for drag or track racing etc. wouldnt be hard to find another if you wanted a set.
the current 2 rear 255's are down to the belts, and the front 235 has 75% tread left
$600 neg
They fit on my 300zx. R33 GTS-T rims fit my zed so i assume they will fit all skylines with the same pattern as R33gtst's..
pick up only.
0405400170 or e2ek1el21@hotmail for MSN or email.
Peace
Matt.
https://www.sau.com.au/forums/topic/69683-fs-17x10wide-mags/
sorry dude i dont have a skyline, your welcome to come try them on for yourself.
Ask doughboy, he may be able to send pics for you
im QLD. gold coast
offset for 300zx is 114.3 and they fit sweet as front and back on the zed.
im QLD. gold coast
I think you mean PCD is 114.3
offsett is distance from the wheel hub to the centre of the rim sorta of a measure of how far the rims wll fit inside the guards
well dont think I can take up that offer anyway since Im in WA ahahha
give us a pm if you're willing to send maybe I'll consider it and a pic on the zed would also help since from memory I think Z32 and R33 GTS-t have very similar offsett on the rears. Just to see how it fits inside the guards
yea my bad, PCD 114.3
probably not going to be worth posting as wheels and tyres are heavy, 30kg in post will be killer! especially to WA
they sat in my gaurds a few cm's but my zeds lowered an inch which makes it worse.
ive had an offer of $350 but im really after $500 guys.
you wont get 10" rims this cheap anywhere. theres $150 worth of tyre on the front rim alone!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
