None of the usual suppliers (Mod Your Car, Slidewize) are no longer able to source new Buddy Club rims. Apparently this is due to the Japanese company closing up shop. Have read a few forums which sorta confirm this:
http://www.jtuned.com/forums/showthread.php?t=373
Pissed me off no end. There's a bit more to it though, I'll see if I can find the other link..
Buddy Club has in fact closed up, the news was a month ago...the P1's are gone forevar!
Similar thing happened to SSR...the Type C's are gone forevar!
Influx of cheap China made rims, like the copies of TSR Type C's I saw here in Taiwan is the main reason. They look identical except for the logo, even the font and colours scene for the logo is identical just the brand name.
Such a pity...both SSR and Buddy Club poured heaps of money into redesigning the wheels with cheaper materials and process but failed to succeed. Hard to imagine but this is the story I was told when I spoke to my supplier in Japan last month. Even my mate at SA told me the same story, they have no more stock. This will only makes these wheels even more sort after as both these wheels models Type C and P1 QF are the lightest and 2nd lightest racing wheels in Japan...lighter than Volks TE37.
I actually heard that it's just the Jap owner (First Inc) going belly up, and that internationally Buddy Club is ok. I spoke with Jeff Ash at C-Red and he reckons that they make start taking orders again quite possibly as soon as a couple of months from now, but no official word.
Vijay
Vijay
I don't know about Buddy Clubs involvement outside Japan, but none of the wheel outlets in Japan can get any more stock then what they already have still remaining.
PS, I know Jeff Ash well :cheers:, put him in contact with a couple of his suppliers in Japan.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
