Hey guys,
Just wondering if a A'pexi SAFC will work on a EA Falcon Turbo.
I have just turbo'd the car and the fuelling aint too great. It's currently got a extra injector in the throttle body along with a rising rate regulator.
The regulator makes it run rich when at idle/off boost, but works well on boost. The extra injector is surprisingly very good on boost as well so I will be retaining it.
I was thinking, as a cheap option for now to get either a Microfueler (which I don't know where to get?!?) or a A'pexi SAFC. The latter seems to be the GO but I'm unsure if the factory ECU would be able to handle the SAFC telling it the engine is boosting.
Does anyone know where to get a Microfueler? What would be the better option? Does anyone know of any good sites with more in depth info on the SAFC?
Thanks,
P.S Fordforums won't know, so don't direct me there lol!
PPS This may seem a bit out of place too, but I thought you guys would no more about this sort of stuff:P
https://www.sau.com.au/forums/topic/69701-safc-or-microfueller/
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
