There is zero chance of finding the connectors at any regular electronics place (Dick Smith/Jaycar etc).
A suitably large and interested auto electrical wholesaler might be able to help but your chances are slim.
I'd either buy a 2nd hand loom, ring Nissan or start calling people who do specialist ECU type wiring (eg ECU installers). Castle Auto Electrics in Vic is one place I can think of off the top of my head who do a lot of conversion wiring and claim to use the factory plugs.
Also, the proper terminating tools are likely to be hidously expensive and therefore cost prohibitive for someone who only wants to do a little bit of DIY wiring.
If you find anything out, keep me updated 'cos I've never managed to get far with this type of enquiry. I'd love to be able to modify my own wiring and still keep it nice and neat and factory looking and free of solder.
no relation the question lukevl
but browny that is a great post full off all the info you need not just a post like
"just do this or just do that" its good to see people actually helping others not just throwing in there 2c
sorry ill stop bitching now :box::D
You could try a you pick it wrecker and comb every EFI Nissan in the joint . Be prepared to have a bastard of a time getting the spade connectors out of the plastic fittings . You can buy very expensive dedicated tools from Snap On , Wurth or Blue Point , or simpy hammer flat the end of a piece of MIG wire which is fine and very stiff . You can replace factory fittings with alternate OEM EFI stuff just remember to join the correct wires !
I though of another alternative , the Haltech (EFI Technology) people use GM style automotive weather proof connectors for their looms and will sell separatly or at least those in Taren Pt Sydney do .
Hope this helps , cheers A .
Actually, if you work out how the terminals are locked in, it's usually quite easy to get them out. Most of the Nissan connectors i've seen use some sort of little locking tab (in some cases two) that fits into a recess in the terminal. A fine scribe or a spare terminal is good for releasing these tabs. The MIG wire suggestion sounds like a great idea too!
Is the GM style stuff that you are referring to the "weatherpak" connectors? I've used them and they are ok, but IMO aren't anywhere near as nice a design or as well made as the OEM Nissan stuff. Also, the weatherpak stuff that is readily available seem to be connectors only - not replacement plugs to connect to OEM sensors etc.
It's relatively cheap and easy to get good condition used connector housings from old looms, but this leaves you with the problem of how to terminate your wiring. I'm not a fan of soldering anywhere in an auto loom so the ultimate thing would be to find a source of OEM terminals and crimp tooling ($$$) and then you could make your own OEM quality looms. The next best alternative is to splice/extend/shorten wiring by soldering, heatshrinking and then carefully wrapping and supporting to ensure the join won't break through fatigue.
Also, finding the range on wire colours to match that of the factory could be difficult.
So at the end of the day, if you are using OEM sensors and management, its probably easier to just get an OEM loom and modify (by soldering) little bits here and there to suit your particular application (what i've had to do).
If your using aftermarket management you could just offload it all onto whoever is providing the management and let them work it out!
Now you've really got me curious , what is your aversion to properly soldered joints ? My preference is to use non insulated terminals that are mechanically wrapped around the wires insulation and the wings closest to the spade end soldered to ensure a gunge proof joint , this is then insulated with shrinkwrap . My tame guru's both came from the rally world so 100+ km/h through creek crossings needs serious long term electrical reliability . Soldered joints take longer and cost more but they usually stand up to hostile environments better IMO . The hineous crimp (pimp) connector is a bean counters rather than a engineers preference I feel . I've had many tell me that aircraft are flying around with pimp joint looms so I'll stick to cars trucks and locomotives , these roll to a stand when they cough and die .............
I'm not here to flame anyone , just like to know the opinions of others .
Have a good weekend cheers A .
By "crimp connector" I am referring to an oem style crimp termination where the terminal crimps onto both the wire and the insulation. The reason I like this type of termination is because the crimp onto the insulation gives the joint good mechanical strength. I've never seen one of these joints fail (but then again I haven't really looked at that much wiring, i'm interested in others experiences).
I really don't see the need to solder one of the above joints, but as long as you don't get too much heat into the terminal and soften the insulation, it might be good insurance in hostile environments like you are talking about.
BTW I'm not referring to the cheapie "squash it flat" type spade crimp terminal - These are the worst of the worst.
The reason I generally don't like soldered joints is because they tend to make the wire brittle if you get too much heat into the joint (easy on fine gauge stuff). And if there isn't any mechanical connection onto the wire then this is a failure waiting to happen.
Splicing/shortening/lengthening wiring is a bit different. It's not that bad to solder and carefully wrap the joint up, however my preference would be to run a whole new section of wiring from terminal to terminal because this doesn't introduce any extra joins where the wiring could potentially fail.
Thanks for the replys. i am using a Motec but I need something to plug into the CAS, TPS, ignitor, coils etc. I just don't want to use the old plastic plugs from a wrecker who wouldn't let me cut them off anyway. My understanding is that Nissan only sells looms not plugs.
Solder is not used due to lead content and longer process time.
Regular hand crimp tools from any electronics shop will do along with a touch of solder to make up for the weaker hand force compared to machine force.
All connectors I can think of use plastic locking tabs, some more than one. The only tool you "need" is a long pin to unlock the tab and pull the terminal out using the wire from the rear. Some connectors will have retaining clips on the side of the housing which you will need to pry open first.
Nissan themselves dont make the connectors but may sell them marked up as P&A, it will likely be tyco, or possibly sumitomo or yazaki who supplies them. Tyco have a relatively useful website where you can search, but due to the shear amount of automotive connectors it will be tough. I am also not sure if they sell retail. Petroject or similar EFI stores have already done the homework for you and would be the easiest but you will pay their margin. There is nothing wrong with cutting up a used loom.
  • 6 years later...
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
