A quicker one than your car at the moment Mark Hehehe...
Sorry I just had to say that!
what size cooler pipes are you running mick that cooler looks huge. But i cant see the pipes coming off the side.
Sorry mick
just had to say it.
hey mick
atleast i can sell my car for more then i paid.
also
what motor and box do you have in urs
oh what is that
r33 stuff
oh
so sorry cause its common as a wrx. COMMON CAUSE PPL HAVE TASTE.
Sorry mate
ill give you 6g for your car.
Hey mick How much does ur insureance cost?
hey mick
also
oh what is that
r33 stuff
oh
Sorry mate
i will give you $4000 cause thats about what the engines cost another $400 for intercooler and piping :) the rest is just scrap metal :(
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
