I was looking at lowering my r33 gtst with some king springs.....
i can get the "lows" (35mm) but i wanted a bit lower...i was told that king springs recommend not putting the "super low" (50mm) springs on because it would be too low, causing the car to be hitting its bump stops?? is this true?
the wheels are 235/40/18
anyone have a better idea....coil overs would be nice but are a bit out of my budget. i thought about 40-50mm lower would be nice without being too extreme and dumb. :D
https://www.sau.com.au/forums/topic/69728-king-springs-too-low/
A 50mm drop will effect the camber; you will need adjustable camber arms to correct. I dont think it will hit the bump stops. Also, the standard shocks don't like being so low and will wear out quickly. Had the super lows on my car and it handled terribly, probably because the geometry was all off. Switched to lows and the ride is much better. I suggest that if you're going to use super lows you will need to invest in additional suspension bits to get the suspension geometry right. Also have 238/18's and there's heaps of space under the gaurds, no problems with rubbing.
yeah i didn't think 50mm's lower would be much of a problem....will have to look in to getting new shocks as well then. Also should get the camber adjusted. Anyone know of something other than whiteline kits? I know they are good, i just want another option to choose from. cheers
well the shocks are not specific to whiteline, apparently they are off the shelf items from bilstein, so you can probably get them cheaper direct.. as for springs, you could also try king springs, but the whiteline springs are not too expensive (around 350) anyway..
there are a lot of options in terms of springs, but i believe that bilsteins are best suited for an r33 in our conditions...
and yes you will need a camber kit if you want to drop it heaps, most suspension places will be able to sell you these...
thanks, well i guess i will be getting that rear camber kit. :) do you really need to adjust the front if lowering 50mm? or do you think it would be ok?
I can get the king springs cheap, so thats what i'll be getting. just have to decide on low or super low. The shocks i will shop around but i will look into the bilsteins ones. cheers
i just measured from the centre of the wheel to the edge of the gaurd, rear is 370mm and the front is 365. i'm thinking now that 50mm lower will be a bit to much for everyday driving. any comments?
i think you should check what the lowest point of the car is before you go buying super lows, who cares if you get them cheap, go out on the weekend and get dicked over because they are too low.
i think its 100mm or 110mm you can have at the lowest point. Most cars out there are illegal when you look at them, just make sure urs isnt, just to be safe :)
or not to be picked on, (AS MUCH) you do after all drive an import :)
good luck
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
