Hmmm...... HKS Actuator set at 14psi (1 bar) minimum on a stock turbo which is over 12 years in use might not be a good idea. Might even blow the turbo in 10mins. lol
Who said it was on a standard turbo?
And 14psi is not quite 1 bar, its .95, which is alot when you want 1 bar.
Edited by W0rp3D
If you look at my initial post, i did mention i want to tune the hks adjustable to stock settings as i have a bad actuator hence i am asking these questions. Sorry if 14psi is not 1bar. I just round the figure up. So it's confirmed, Hks actuator is factory preset at 14psi minimum hence i cannot use it on a stock turbo as i cannot tune it below 14psi. I was hoping to get it down to like 7psi or so.
3) If you mean that it wont go under 14psi, when i first put mine on it was at 10psi, i did not try to put it lower as i wanted more boost but i cant see why you could not drop it by a few psi.
Even if it wont go below 10psi that is still safe for a standard turbo.
Edited by W0rp3D
Scratch that last question. I forgot that you weren't using it on a stock turbo. lol
Im using it on a high flow with a vg30 rear, but i dont remember, best way to do it is just put it on and make sure there is tension on it and take it for a spin, either you or a passenger keep and eye on it if it starts to go to high pull over and adjust it.
  • 5 months later...
