RedEmblem Posted April 8, 2005 Share Posted April 8, 2005 Hey guys, I noticed last night that for the first time, when my car was cold, when I took my foot off of the clutch (quickly - when it was in neutral in the garage) there was a metalic sound coming from it - like metal hitting metal. Doesn't seem to impact performance at all, just don't know what it was from :Oops: RE. Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/ Share on other sites More sharing options...
drakan69 Posted April 9, 2005 Share Posted April 9, 2005 My ute makes a noise when i do the same thing, however it dosn't have to be cold. I've been told it's the through out bearing on the clutch. Ofcorse holden and Nissan are a world apart. p.s i carn't spell for dog's balls, if you haven't guess. Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290325 Share on other sites More sharing options...
frog_stompR31 Posted April 9, 2005 Share Posted April 9, 2005 thrust bearing may be ****ed does it do it all the time or only when you let the clutch out ...? Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290762 Share on other sites More sharing options...
Husky33 Posted April 9, 2005 Share Posted April 9, 2005 yeah mine does the same. IT happens all the time but as soon as any slight pressure it put on the clutch it goes away. I've been told by numerous people it's the thrust bearing..nothing major. If u find u have to put the clutch all the way in to get rid of the sound it could be something different Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290823 Share on other sites More sharing options...
RedEmblem Posted April 9, 2005 Author Share Posted April 9, 2005 Well, the metallic sound only happens sometimes (40% I guess) and the sound is louder the faster I take my foot off of the clutch. There is another sound, a squeaky sound, which occurs 99% of the time. When I depress the clutch slightly it goes away. Was told that may be the thrust bearing. Also, when under pressure (acceleration) sometimes my gears crunch almost like I havn't put the clutch in at all. I've been told it may be a leaking master cylinder. Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290832 Share on other sites More sharing options...
benm Posted April 9, 2005 Share Posted April 9, 2005 If it sounds like a metal whirring noise then it's likely to be the thrust bearing, i've worn out 2 in 2yrs. The annoying think is I believe they are a $20 part although it doesn't take much longer to throw in a new clutch so I just put up with it. Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290912 Share on other sites More sharing options...
rb25detcalais Posted April 9, 2005 Share Posted April 9, 2005 Definately the thrust bearing....on the other hand with your crunching noises, you would want to hope it is a buggered master cylinder.... if your synchros have gone on your box that can be major dollars.... Link to comment https://www.sau.com.au/forums/topic/69767-sound-when-taking-foot-off-of-clutch/#findComment-1290943 Share on other sites More sharing options...
