All
I've just done a full engine rebuild on my R32 GTR (almost run in now) and I'm planning on taking it to the next level. I have the following bits ready to install
PCF + HC
Tomei Adj CAM gears in/out
HKS 550cc injectors
I've just picked up a pair of RB25 AFMs (herd they were a cheap upgrade) and I was wondering if ....
the PFC has a setting for these
can I swap them for the std AFMs before fitting the PFC
Anyone know where I can get a piping kit for these to suit my GTR - I have pods (Ms I think) can I keep those and just swap the pipe between the pod filter and the AFM
will I also need to swap out the hose between the AFM and the turbo (flexible ?)
https://www.sau.com.au/forums/topic/69793-r32-gtr-with-rb25-afms/
Yes the power fc has a setting for the rb25 afm's. i highly doubt that you would be able to buy a bolt on intake kit to suit though, you will probably have to get something made up and there is no reason why you couldnt use your current pods but due to the larger diameter of the afm's they probably wouldnt be big enough. As for fitting them before the power fc, i dont think it would be overly wise due to the standard computer not being tuned to suit, i personally would wait untill i got the ecu in. Ive heard that the rb25 afm isnt all that good on a rb26 due to the fact that they cant hanlde as much air up in the higher revs and the calibration is slightly different. I personally would (and have) opt for a pair of z32 afm's. I hope that helps you out a little.
I dont believe the stock ecu will support them. If you have the new powerfc, then option 4 under airflow setting lets you use twin rb25 afms. Im not sure what the value is for the older powerfc (as in the one that came seperate with the hand controller).
The newer powerfc supports:
Option 1: BNR33 Normal
Option 2: BNR32 Normal
Option 3: Power Intake
Option 4: 80(squiggle O) RB25 Air-F (twin rb25 afms)
Option 5: 80(squiggle O) VG30 Air-F (twin z32s afms)
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
rb25 afm's on mine with the PFC and 2530's . Car did run with rb25 afm's straight up but not well and was tilt trayed to the tuner . If your only looking for 300rwkw then they will have plently of headroom . pnblight on these forums only maxed his out at close to 500rwhp on his 33 GTR .
very good work - RB25's will be fine for me - target is only 280-300rwkw
Mate, I managed to get 297rwkw with my standard GT-R a/f meters, I have RB25 a/f as well but could not put them on yet because of the same reason you do i.e. piping and pods do not fit.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
